23842 Discussions
Intel(R) G41 with display driver update = Restart loop
Hello Community ,
My question defines my exact problem am facing ,
Am using Inter(R) G41 express chipset in windows 7 N and facing system restart issue when ever I tried to reduce the resolution or update my display drivers.
System working great in safe mode and also in normal mode if I disable display drivers " Inter(R) G41 Express chipset " or
"Intel (R) G41 Express Chipset ( Microsoft Corporation - WDDM 1.1 )" ...
If I enable display drivers the problem continues ...
Facing the same now in windows 10 pro.. , but I have checked other sources many were using old version of display drivers and its working fine ..
Loops Restarting...
Hi Prakash_suren,
In order to collect more information about your system, could you please attach the result of the Intel® System Support Utility?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Hellen.
Hi Prakash_suren,
I was checking this thread and I was wondering if you were able to resolve this problem.
Hellen.
I think i resolved by removing one of the RAM..
One of my ram causing the issue. After removing , now the pc working smooth with windows 10..
Hi Prakash_suren,
Great, Thank you for the update, if there is anything else you need, do not hesitate to contact us back.
Hellen.
