23832 Discussions
Intel(R) HD Graphics Driver is not installing on Win 7 32 bit OS
Hi I am trying to install Intel (R) HD Grpahics driver on a system with Windows 7 32 bit OS but I am getting following error as shown by the log file:
[INF - -5]
Installing F:\WinVista\Graphics\igdlh.inf
INF = F:\WinVista\Graphics\igdlh.inf
0x0: ENTER: DriverPackageInstallW
0x0: DRIVER_PACKAGE_LEGACY_MODE flag set but not supported on Plug and Play driver on VISTA. Flag will be ignored.
0x0: Installing INF file 'F:\WinVista\Graphics\igdlh.inf' (Plug and Play).
0x0: Looking for Model Section [Intel.Mfg]...
0x0: Installing devices with Id "PCI\VEN_8086&DEV_0102&SUBSYS_1587103C&REV_03" using INF "C:\Windows\System32\DriverStore\FileRepository\igdlh.inf_x86_neutral_982061e4c2af9232\igdlh.inf".
0x0: Will force install because driver is not better and force flag is set.
0x0: ENTER UpdateDriverForPlugAndPlayDevices...
0x5B4: RETURN UpdateDriverForPlugAndPlayDevices.
0x5B4: Installation failed.
0x5B4: PnP Install failed.
0x0: Attempting to rollback ...
0x0: Rollback completed
0x0: Successfully deleted driver store entry 'C:\Windows\System32\DriverStore\FileRepository\igdlh.inf_x86_neutral_982061e4c2af9232\igdlh.inf'.
0x0: Could not delete properties for driver store entry 'C:\Windows\System32\DriverStore\FileRepository\igdlh.inf_x86_neutral_982061e4c2af9232\igdlh.inf'.
0x0: RETURN: DriverPackageInstallW (0x5B4)
! DriverPackageInstall error 0x5B4
IIF will NOT initiate reboot
Exit code = 0x5B4
ResultCode = 1460
<<< 10/30/2010 16:14:38:108
Can anyone tell me how to fix this error?
Win7Dev
No, the readme file on my package says this:
Alpha/Beta/Production Candidate Releases
Microsoft Windows Vista*
Microsoft Windows* 7
Driver Revision: 15.21.2.2224
October 22, 2010
Should I use this or not?
DSilv11
Valued Contributor III
well,
That looks loke a newer package than anything i can find on Intels web site which makes me wonder.
Any driver listed as a "Canididate" usualy means it has not been tested yet.
You may want to try the driver at the link above and see if it installs for you.
October 22, 2010
Thanks Doc_SilverCreek. I tried with the link that you provided it says the system does not meet the minimum requirements while the beta one at least fails in the end. Also on that system I have 2 GB RAM, Intel (R) CPU, 9GB free space on the hard drive. What else I am missing?
DSilv11
Well, I guess that message is slightly more informative.
What board, processor and chipset are you using?
The README says you need :
* 1. SYSTEM REQUIREMENTS
1. The system must contain one of the following Intel
Chipsets/Processors:
Intel(R) Pentium(R) Processor
Intel(R) Core(TM) i3 Processor
Intel(R) Core(TM) i5 Processor
Intel(R) Core(TM) i3 Mobile Processor
Intel(R) Core(TM) i5 Mobile Processor
Intel(R) Core(TM) i7 Mobile Processor
Intel(R) B43 Express Chipset
Intel(R) G41 Express Chipset
Intel(R) G43 Express Chipset
Intel(R) G45 Express Chipset
Intel(R) Q43 Express Chipset
Intel(R) Q45 Express Chipset
Mobile Intel(R) GL40 Express Chipset
Mobile Intel(R) GM45 Express Chipset
Mobile Intel(R) GS45 Express Chipset
2. The software should be installed on systems with at
least 1 GB of system memory.
3. There should be sufficient hard disk space in the
directory on the system in order to install this
software.
The drivers included with this distribution package are
designed to function with all released versions of
Microsoft Windows Vista* or Microsoft Windows 7*.
Please check with your system provider to determine the
operating system and Intel Chipset used in your system.
OK so here is the requested info:
Motherboard - Hewlett -Packard 1587h
Chipset - Intel C206 (Cougar Point Server Advanced)
CPU - Intel Core - 2400
Please let me know if I need to update any of these. Please provide location tp update also.
Thanks in advance,
Avnish
