A newly installed Windows XP SP3 with all updates installed quite randomly and quite often BSOD's (crashes) in the newest Intel driver (14.42.8.5303).
I'm not running any graphical (3d) applications. I have an Intel Core i5 530 CPU.
For the last two hours I've already had three crashes. Three minidumps can be downloaded http://www.mediafire.com/?0zsbfouua90ggyy here.
Update: the crashes most often occur when I'm working in Miscrosoft Visio 2003. The computer also crashes in Mozilla Firefox 3.6.12.
Message was edited by: Artem Tashkinov
I wonder who's answering e-mail requests:
Intel provides generic versions of the Intel(R) graphics drivers for general purposes through the Intel Download Center. However, your computer manufacturer may have altered the features, incorporated customizations, or made other changes to the graphics driver software or software packaging that they provide for your computer. To avoid any potential installation incompatibilities on your computer, Intel recommends that you first check with your computer manufacturer and use the driver software provided by your computer manufacturer.
To download the latest generic driver from the Intel Download Center, visit: http://www.intel.com/support/graphics/detect.htm http://www.intel.com/support/graphics/detect.htm
If those "Blue Screens Of Death" happen only when Microsoft* Visio* 2003 is opened, you may need to check with Microsoft* for any patches or updates.
You can also, remove and reinstall the application for testing purposes.
I have never recieved such a "profound" off-the-shelf answer, please, do not send people such atrocities in the future. It might enrage them to death.
1) User applications cannot by theory crash OS via its graphics drivers. If it happens then most likely graphicals drivers are to be blamed.
and
2) This piece of hardware is intended to be run by genuine Intel drivers (as all Intel Core i3/i5 CPUs contain identical GPU).
Here comes the first bump.
So maybe if you provide some useful information, some one might be able to assist you?
After all, this is a USERS forum. A lot of the moderators are Intel folks that know quite a bit, but a lot of the inputs come from users.
Mini Dumps are nice as long as someone is willing to go to an unknown site and download unknown files and load them into their system so they can read the message that was likely displayed on your screen or is in your event log.
If it was not for the fact that this is a virtualized crash and kill system, I would not touch your downloads.
----- 32 bit Kernel Mini Dump Analysis
DUMP_HEADER32:
MajorVersion 0000000f
MinorVersion 00000a28
DirectoryTableBase 61bb3000
PfnDataBase 81043000
PsLoadedModuleList 805634c0
PsActiveProcessHead 80569658
MachineImageType 0000014c
NumberProcessors 00000004
BugCheckCode 000000ea
BugCheckParameter1 8680e268
BugCheckParameter2 86a02e98
BugCheckParameter3 87e8dc98
BugCheckParameter4 00000001
PaeEnabled 00000000
KdDebuggerDataBlock 805532e0
MiniDumpFields 00000cff
TRIAGE_DUMP32:
ServicePackBuild 00000300
SizeOfDump 00010000
ValidOffset 0000fffc
ContextOffset 00000320
ExceptionOffset 000007d0
MmOffset 00000000
UnloadedDriversOffset 00000000
PrcbOffset 000012f8
ProcessOffset 00001f48
ThreadOffset 000021a8
CallStackOffset 00002400
SizeOfCallStack 0000082c
DriverListOffset 00002c30
DriverCount 00000081
StringPoolOffset 00005280
StringPoolSize 000011b8
BrokenDriverOffset 00000000
TriageOptions 00000000
TopOfStack b8a3c7d4
DebuggerDataOffset 00001068
DebuggerDataSize 00000290
DataBlocksOffset 00006438
DataBlocksCount 00000001
Windows XP Kernel Version 2600 (Service Pack 3) MP (4 procs) Free x86 compatible
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805634c0
Debug session time: Sat Oct 23 03:51:33 2010
System Uptime: 0 days 4:28:24
start end module name
804d7000 806ff000 nt Checksum: 0021A5B7 Timestamp: Tue Apr 27 06:54:14 2010 (4BD6EC86)
Mini Kernel Dump does not contain unloaded driver list
Unable to examine unloaded module list
Finished dump check
Who's hardware are you running? Have the drivers you are using been tested on that product?
Vendors do edit the drivers for quirks in their hardware, Running a generic driver can cause the issues you are seeing.
As far as a BugCheckCode 000000ea http://www.ehow.com/how_5579049_stop-0x000000ea-infinite-loop.html http://www.ehow.com/how_5579049_stop-0x000000ea-infinite-loop.html
You either have 1) bad driver, 2) bad hardware 3) bad ram. or a bad program looping the video
It's not really my problem, it's my friend who has this issue so I created this thread on his behalf.
As for you investigation - thank you for pointing me out what I already know, I've already (win)dbg'ed these crash dumps and already found out this crash is due to an infinite loop in graphics drivers. Alas, you haven't showed that, but dbg clearly shows that the system stuck in Intel drivers.
As for you suggesstion of using vendor supplied drivers: the laptop crashes with original Dell drivers.
As for you suggestion that maybe some of my hardware is faulty: no, we've run memtest for a while, also I ran some CPU intensive applications (which test system stability) - non of them has showed any anomalies or problems, so it's very likely my hardware is not faulty.
The system is otherwise rock solid and doesn't crash.
Crashes also occur in Mozilla Firefox 3.6.12:
"The display driver igxprd32 has stopped working normally. Save your work and reboot the system to restore full display functionality. The next time you reboot the machine a dialog will be displayed giving you a chance to report this failure to Microsoft."
![](/skins/images/44D6FBC13D1AFC21DF3F0C7813903D74/responsive_peak/images/icon_anonymous_message.png)
