23784 Discussions
Intel(R) HD Graphics Family saturation problem
Hey guys, im trying to change the saturation and if im not using a hdmi cable it works just fine, but if use a hdmi cable with my samsung syncmaster 2033m (monitor) the option to change the saturation dissapears and it shows me an option to activate YCbCr. Can anyone help?
processor: i5-4200U @ 1.6GHz
graphics: GeForce GT 740M
OS: Windows 8.1 Pro
Hello rennerz,
Thank you for bringing this matter to the Community. I am sorry to hear you are having issues with the Saturation option.
Could you please provide your https://www.intel.com/content/www/us/en/support/articles/000005848/graphics-drivers.html Report for Intel® Graphics Drivers report?
To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box.
Amy C.
Here it is.
English version:
Intel(R) HD Graphics 4400
Report Date: Tuesday, November 21, 2017
Report Time [hh:mm:ss]: 3:52:58 PM
Driver Version: 10.18.14.4578
Operating System: Windows* 8.1 Pro (6.3.9600)
Default Language: Portuguese (Brazil)
Physical Memory: 12192 MB
Vendor ID: 8086
Device ID: 0A16
Device Revision: 09
Video BIOS: 2167.0
Current Resolution: 1366 x 768
Processor: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
Processor Speed: 1596 MHz
Processor Graphics in Use: Intel(R) HD Graphics 4400
Shader Version: 5.0
OpenGL* Version: 4.3
OpenCL* Version: 1.2
* Microsoft DirectX* *
Runtime Version: 11.2
Hardware-Supported Version: 11.1
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 12.2 inches
Vertical Size: 6.69 inches
Supported Modes
1366 x 768 (60p Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 3F 03 00 00 00 00
00 18 01 04 90 1F 11 78 EA EB F5 95 59 54 90 27
1E 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 D0 1D 56 F4 50 00 16 30 30 20
35 00 36 AE 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 34 30 57 48 38 2D 54 4C 41 31 00 51
* Other names and brands are the property of their respective owners.
/thread/119720 rennerz, thank you for the information.
I did a search regarding this matter and found out that the behavior you are seeing is expected. The Saturation option actually replaced by the feature called YCbCr which already handles the saturation for the TV.
Amy C.
I see, thanks for the reply, is there anyway I can change the saturation with the YCbCr? To get more saturation... Thanks
The option for the YCbCr is enabled by default, and it can only be enabled or disabled from the Intel® HD Graphics Control Panel. Unfortunately, it does not include a slider in order to regulate the effect and change the saturation. Have you checked if your TV includes a saturation option? That could help.
Amy C.
Yes, thank you for the support!
