23832 Discussions
Intel(R) Iris(R) Xe Graphics not supporting a 75hz Monitor
Reyyan
So, I am trying to connect my laptop (Dell Inspiron 5510) which is using Intel (R) Iris(R) Xe Graphics. The laptop's screen is 60hz and 1080p so never ran into this issue before but now I bought an external 1440p & 75Hz monitor. The 1440p part is working fine but the monitor seems to be locked at 60Hz only. Since my laptop has no DPI to DPI port, I am using HDMI to HDMI (the hdmi is 2.1). Will using an hdmi to dpi convertor fix this issue or what else should I do?
Andres_Intel
Hello Reyyan,
Thank you for posting on the Intel®️ communities. I see that you are having resolution issues with your Intel® Iris® Xe Graphics, I understand how frustrating this can be. I will be happy to help you.
We do not recommend using video adapters/converters/docking stations, this may cause compatibility issues.
To have a better understanding of the situation, please answer the following questions:
Andres P.
Andres_Intel
Hello Reyyan,
I am following your case to know if you were able to run the Intel® SSU.
Andres P.
Andres_Intel
Hello Reyyan,
Andres P.
lenovo-l24q-35
i have the same problem, my laptop screen is 2.8k at 90hz, the monitor is lenovo l24q-35 2k 75hz. there isnt an option for 2560 at 75hz, only 2560 at 59hz.
