22671 Discussions
Intel UHD 620 graphic when connect 2 monitor on extend mode then resolution not same (monitor 1 resolution high but monitor 2 resolution is lower)
NSuva
How to fixed.
AlHill
Download, run,, and ATTACH (using the paperclip under the toolbar) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Doc
NSuva
@Al.Hill How to check ?
AlHill
Doc
n_scott_pearson
Are you saying that you think there's a problem because the resolutions are the same? This is perfectly normal and expected!
Are you perhaps thinking of Collage Mode (where lowest resolution is used for both)? I believe that this mode is only supported for three monitors.
