23854 Discussions
Intel UHD 620
_xReTr0_
I was about to play Minecraft the other day and it said Bad Video Driver. I went to the Display Adapters in Device Manager ad it said it was outdated. I upgraded it but it said there was an error upgrading it. I tried to reinstall it but I couldn't. ANy solutions to my problem?
Victor_G_Intel
Hello _xReTr0_,
To better assist you, please provide the following log from your system and provide the information requested below to continue with the support.
-DXDIAG
  • Go to Start > Run or Windows Key + R.
  • On the Run prompt, type "dxdiag" then click OK.
  • On the DirectX Diagnostic Tool window, click on Save All Information.
  • Browse to a folder, type in a filename then click Save.
- When you updated the driver did you use any tool, or did you complete the update manually? If you did it manually where did you download the driver from our website or someplace else?
- Did you receive any specific error message after attempting the update?
I look forward to hearing from you.
Victor G.
Intel Technical Support Technician
_xReTr0_
I did it manually and downloaded it from the website. Opened the setup and a few minutes later it said "The Setup was unable to install one or more drivers".
Victor_G_Intel
Hello _xReTr0_,
We appreciate the information provided, to continue with the support please provide the following log from your system.
-DXDIAG
Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
Victor G.
Victor_G_Intel
Hello _xReTr0_,
Please let me know if you need further assistance.
Victor G.
Victor_G_Intel
Hello _xReTr0_,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer be monitored
Victor G.
