22749 Discussions
Intel UHD 630 to 10 bit monitor
Vincentius
I have an Lenovo AIO (Lenovo ideacentre A340-221CB) AIO with chipset Core i5-9400T which internally graphics is using Intel Graphics UHD 630. I just bought extended monitor ThinkVision P27u-20 that should worked in 10 bit color depth. I need it for photography calibration and designing product. I connect it using HDMI port.
Badly, my new monitor is still working on 8-bit depth color. Are there any solution to this problems?
MUC
Honored Contributor I
How Do I Set Color Depth or Color Format in the Intel Graphics Command Center?
If the options described in this article do not appear on your device, then unfortunately there is no solution.
