22793 Discussions
Intel UHD 730 Graphics VGA monitor
Ivan_Li
Hi all.
I have been using HP Pro Tower 400 G9 Desktop that has 3 video outputs. HDMI, DP and VGA.
Driver installed is version 32.0.101.5768 from july 24.2024.
On this PC I have connected 3 monitors.
Problem is that monitor that is connected to VGA port does not display higher resolution that 1024x768.
When I use driver from HP i have higher resolutions available.
Other 2 monitors work fine with full HD resolution.
How do I solve this?
Thanks in advance
Edit: I've had some issued with HP driver when PC stays locked and colleagues suggested switching to Intel driver, which solved the issues for him.
MUC
Honored Contributor I
HP Pro Series 400 G9 Desktops PCs - QuickSpecs
I think you will have to stick with the HP drivers as this optional VGA solution is not a generic Intel solution. The other problems would then have to be reported to HP Support.
RonaldM_Intel
Hello @Ivan_Li
I see the "HP Pro Tower 400 G9" designation cover a wide range of hardware configurations.
Please run the report from Intel Graphics Command Center while having all 3 monitors connected and upload here for analysis.
Also run the Intel SSU report to get a broader perspective on the current hardware and software configuration.
I look forward to hearing from you again.
Ronald M.
MUC
Ivan_Li
Will do stick with HP for now.  Thank you both.
Kind regards,
Ivan
