22673 Discussions
Intel UHD 750 Graphics - how to set saturation?
Daniel_Turus
Hello!
I have a i5 11600k CPU with the latest driver installed. In the Intel Graphics Command Center there isn't any option for setting the `saturation` of the colors that are being rendered by the iGPU.
On the older models (for example i5 6400 there was an option like this in the Color Settings -> Advanced -> Hue / Saturation.
Does this feature has stopped being developed on the newer iGPUs?
Thank you!
AndrewG_Intel
Hello @Daniel_Turus
In order to provide you with the proper information, could you please confirm or provide us with the following details?
1- Why are you trying to change color settings using the "Hue / Saturation" feature? What are you trying to achieve?
2- Maker and model of the monitor/display(s) regarding this inquiry.
3- What type of cables and video port connection are you using? For instance, HDMI*, DisplayPort* (DP), DVI, etc on both sides (monitor and computer). Also, are you using any type of video/cable adapters, converters, or dockings? Please provide details.
4-Report for Intel® Graphics Drivers following the steps on the link. Make sure the monitor(s) in question is connected to the computer when generating the report.
5- Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system:
  • Download the Intel® SSU and save the application on your computer
  • Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click Next and click Save.
  • Once you have saved the file (.txt file), please attach it to your reply.
To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
AndrewG_Intel
Hello Daniel_Turus
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Andrew G.
AndrewG_Intel
Hello Daniel_Turus
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
