23687 Discussions
Intel UHD Graphics 620
Daviduccio
Intel UHD Graphics 620 quando è presente questo driver nei pc non riesco a duplicare l'immagine dello schermo tramite il proiettore, sistema operativo windows
AlHill
Are you using a splitter to drive the monitor and projector?  If so, there may not be enough power to drive the projector.  You need a powered splitter.
If not the case,  So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
