22936 Discussions
Intel® UHD Graphics 630 + BenQ EW2780 & no HDR
Lazarus1
Good day, i have an Intel® UHD Graphics 630 integrated into the mother board ASRock H310M-HDV/M.2
I bought a BenQ EW2780 , and a HDR cable (kinseda 4K UHD). All intel drivers up to date.
I cannot manage to turn HDR on, it is always running simulated.
Can you help?
Sebastian_M_Intel
Hello Lazarus1,
Thank you for posting on the Intel® communities.
I would like to let you know that High Dynamic Range (HDR) is supported on 7th generation Intel® Core™ Processor and newer platforms running Windows® 10. However, it needs a lot of "ingredients" to properly work. For instance, HDMI version 2.0a is required. Your motherboard seems to have HDMI 1.4.
In order to confirm this information, please provide the following:
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
  • Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
  • Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2. Provide the Report for Intel® Graphics Drivers, follow this link
3. From your PC to the monitor, are you using a straight HDMI connection? Or do you use any adapter or converter in behalf?
Sebastian M
Intel Customer Support Technician
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
Sebastian_M_Intel
Hello Lazarus1,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M
Sebastian_M_Intel
Hello Lazarus1,
We have not heard back from you, so we will close this inquiry. As we mentioned, this problem seems to be related to a motheboard limitation; you may want to double-check with ASRock* for further help.
If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Sebastian M
