23266 Discussions
Intel UHD Graphics 630 doesn't recognize a Panasonic projector
kilpikonnavoimaa
Hello!
I'm having trouble connecting my Panasonic PT-AE3000E projector to my HP ProDesk 600 G4 SFF, which has Intel UHD Graphics 630. I'm using a displayport-HDMI-adapter and an HDMI cable.
The HP doesn't recognize the projector at all. I've tried all three of the hdmi-ports the projector has and both displayports on the pc. The pc does recognize other screens through both displayports and other monitors work properly with it.
My old laptop recognizes the projector and connets without a problem (using an HDMI cable with a minidp-HDMI-adapter at the laptop-end) and the projector works fine with that older machine.
The UHD Graphics has 31.0.101.2111 driver, dated 19.7.2022 which seems to be the newest one.
What should I do? Roll back drivers?
MUC
Honored Contributor I
Year of launch: 2008
1920 x 1080 @ 60 Hz
3 x HDMI 1.3a
HP ProDesk 600 G4 Business Desktops PCs - QuickSpecs
2 x DisplayPort 1.2 (DP++)
I think it all depends on the adapter you are using. Do you have a link to the product?
kilpikonnavoimaa
Thank you for your reply!
This is the adapter: https://aurdel.com/se/en/103768
It doesn't have much info, seems to be some Nordic brand.
Adapter DisplayPort 1.4 male-HDMI female aud, 0.2m
  • HDMI version 1.4/ DisplayPort 1.2
MPN: 103768
Article number: 103768
EAN: 5706470091665
MUC
Unfortunately, the information on your current adapter is not clear. I think you will achieve the best compatibility if you use a DP++ adapter from HP.
According to the manufacturer, the DisplayPort connectors on the HP ProDesk 600 G4 SFF support DP++, also known as "Dual-Mode". This means that when a DP++ to HDMI adapter is connected, the computer sends HDMI signals instead of DisplayPort signals on an electrical level.
Please search online shops in your country for the part number F3W43AA. This adapter from HP should also be available in the HP online shop. It is very cheap.
