23850 Discussions
Intel® UHD Graphics 630
John222
I have  MSI laptop MS-16PS.
I found out the Graphics Intel UHD 630 causes the laptop restarts but only when I connect a power charger.
Without a power charger laptop works OK. If I disable the graphics Intel UHD 630 ( in Device manager) the laptop works OK as well.
I tried to install gfx_win_101.2115 driver but it finishes with error
0xe000023d  "Unknown error"
exit code
exit code: 1
Can anyone please help?
Thank you
AlHill
Go to MSI and get them to help you with updating your bios.
Also, if this does not correct the problem, consult with MSI regarding a hardware problem.
John222
Why do you think it should be the BIOS problem?
AlHill
Because you are talking battery and charger.
Is there some reason you cannot do a simple bios update and eliminate that as a concern?
Either update the bios or not, your choice.
