22988 Discussions
Intel VGA - "pc does not meet minimum requirements"
jhong18
Specs:
Acer AO756-2808 Netbook
Intel Celeron CPU 877 @ 1.40Ghz
Intel HD Graphics 2000
Windows 8.1 Pro 64Bit
8G Dual Ram
120SSD
Clean install on new SSD.
Updated Intel Chipset 9.4.0.1026, Intel HD Graphics 2000 9.17.10.3347, and Intel MGMTEngine 9.5.14.1724.
Completed Window Updates.
Can't update Intel VGA 10.18.10.3304. "Fail to meet minimum requirements".
Any idea?
Ran Intel Driver Update Utility:
Only 5 drivers showed up. See attached.
Kevin_M_Intel
Hi JH,
Sorry to hear you are having problems installing the driver.
I recommend you uninstalling the current driver from the computer and downloading the following driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23377&lang=eng&OSVersion=Windows%208.1%2C%2064-bit*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
If you are still getting the same message, I recommend you trying the Manual Driver Installation. Here are the steps:
http://www.intel.com/support/graphics/sb/CS-033916.htm http://www.intel.com/support/graphics/sb/CS-033916.htm
