22824 Discussions
Intel arc b580 refresh rate half when exiting to desktop after playing windowed game
Liam2573
Intel arc b580 refresh rate half when exiting to desktop after playing windowed game have to restert pc for it to stop and also having problems with global refresh rate mode always being greyed out unless i change scaling mode
RandyT_Intel
Hi @Liam2573,
  • Please provide the SSU log report and share it here so I can review your system's configuration and any connected peripherals (monitors) make and model?.
  • When did the issue first occur?
  • Have you made any software or hardware changes to the system recently?
  • What troubleshooting steps have you tried so far?
  • Which specific game are you playing when you encounter the refresh rate issue?
  • What is the current refresh rate setting for your monitor or display?
  • Have you recently updated your graphics drivers? If so, did the issue start after the update?
  • What scaling mode are you currently using, and have you tried switching to different modes?
  • When the global refresh rate mode is greyed out, what specific changes do you make to enable it?
  • Have you tried using a different monitor or display to see if the issue persists?
  • Could you provide a screenshot of your current display settings, including the scaling mode and refresh rate options?
Warm regards,
Randy T.
RandyT_Intel
Hi @Liam2573,
Warm regards,
Randy T.
Anonymous
Not applicable
Sir night reign issues are not solves , you wont even check those posts , get it fixed
RandyT_Intel
Please create a separate ticket so we can further assist, you may also provide the community thread here so I can check it on my end.
RandyT_Intel
Hi @Liam2573,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Warm regards,
Randy T.
