22664 討論
Intel command center how to create hotkey or desktop shortcut for color profile
pertholds
初學者
3,613 檢視
I am running a 12th Gen Intel(R) Core(TM) i7-12700H 2.30 GHz
i have the intel arc and xe graphics driver
I have intel command center and I created some color profiles,
now I want to quickly switch between color profiles, by means of a hotkey or a desktop shortcut,
but I cant seem to find a way to do it
I have found a section on hotkeys, but the only option is an hotkey to open the command center, I dont need that.
Thanks!
0 積分
1 解決方案
VonM_Intel
主席
3,188 檢視
Hi, pertholds.
I appreciate your quick response. Unfortunately, it seems that the IGCC beta does not currently offer the option to assign hotkeys to profile changes. I apologize for any confusion caused by mentioning the IGCC beta earlier.
While the current options may not meet your immediate needs, I will certainly endorse your feedback regarding the desire for hotkey or shortcut functionality to our technical team. Your input is valuable as we strive to improve our products and user experience. If there are any other questions or concerns you have, please don't hesitate to let me know.
Von M.
在原始文章中檢視解決方案
8 回應
pertholds
初學者
3,551 檢視
any help?
VonM_Intel
主席
3,419 檢視
Hi, pertholds.
Thank you for posting in our Community.
We will need to do further research on this matter and post the response on this thread once available.
Von M.
VonM_Intel
主席
3,300 檢視
Hi, pertholds.
Thank you for patiently waiting.
It's great to hear that you're utilizing the Intel Command Center and have created color profiles for your system. To access additional features, you may utilize the IGCC beta versionNevertheless, it's important to note that the capability to switch between color profiles using hotkeys is presently unavailable. The default hotkeys are outlined in the provided screenshot.
Subsequently, I would recommend sharing the articles below to aid in using the IGCC beta:
Looking forward to your response. Have a nice day!
Von M.
NormanS_Intel
主席
3,252 檢視
Hello pertholds,
I wanted to check if you had the chance to review the information we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Norman S.
pertholds
初學者
3,237 檢視
Hello NormanS,
I have reviewed the reply to my question, and it seems that VonM simply informed me that its not possible to switch profiles with hotkeys
I dont know how something that is not possible can be resolved
VonM_Intel
主席
3,225 檢視
Hi, pertholds.
I appreciate your response. While it may not be possible to switch profiles with hotkeys as initially hoped, there will be alternative methods or workarounds.
Subsequently, we would recommend sharing the steps below to aid in using the IGCC beta:
Customize hot keys in the Intel® Graphics Command Center
  1. From the Windows Start Menu, search for Intel Graphics Command Center. Double click the Intel® Graphics Command Center icon to open the application.
  2. Click System in the left navigational menu.
  3. Customize the hotkey combinations in the Hotkeys tab.
Customize hot keys in the Intel® Graphics Control Panel
  1. From the Windows Start Menu, search for Intel Graphics Control Panel. Double-click the Intel® Graphics Control Panel icon.
  2. In the Intel® Graphics Control Panel, click Options and Support.
  3. Navigate to the Hot Key Manager in the left navigation menu.
  4. Select the hot key that you want to personalize.
  5. Once the changes are made, select Save Profile
The Intel® Graphics Control Panel is available on systems that use Intel® Graphics Controllers with the correct drivers installed.
Please be guided that the original equipment manufacturers (OEM) can disable certain hot-key functions. You may not be able to select a new hot key combination if it is already being used for another application.
For more information, please visit these articles/link below:
Von M.
pertholds
初學者
3,209 檢視
Thanks VonM for the reply,
if there is no option to assign hotkey to a profile, how can I change a profile with an hotkey?
You just admitted that its not possible to change a color profile with an hotkey
I dont understand why you are sharing steps to IGCC beta, when you said that that IGCC beta does not contain hotkey options to change profiles.
I am only interested in changing profiles by pressing an hotkey, or creating a shortcut on my desktop I can double click to change the profile, without having to boot up the command center, wait for it to load and navigate all the menus manually, I want a fast and easy instant change from pressing a shortcut
VonM_Intel
主席
3,189 檢視
Hi, pertholds.
Von M.
回覆
