23832 Discussions
Intel graphics command center resolution problem
ThePhantom1708
So, I wanted to change the resolution of my pc. Hence, I went to the display tab and and to the resolution section but when I tried to change it no options were showing up and I could not change the resolution.
Jean_Intel
Hello ThePhantom1708,
To have a better understanding of your issue, please provide me with the following:
  • Were you able to change the resolution of your monitor before?
  • Is this a laptop or a desktop? If it is a laptop, are you changing the resolution of the built-in monitor?
  • Create a report using the:
Intel®️ System Support Utility (Intel®️ SSU)
Intel® Graphics Command Center:
  • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
I hope you are doing fine.
Jean O.
Jean_Intel
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
