23484 Discussions
Intel graphics mismatch? 31.0.101.3962 / 31.0.101.4255
blfuentes
I got an update from the intel driver & support assistant to update the graphic card to the latest version 31.0.101.4255 but since I installed it, I get the windows update to show me I have the 31.0.101.3962 available. I assume the 4255 is a newer version than the 3962...
Any of you with this issue? The processor is a 12th gen intel i7 12650H and running Windows 11 22H2 22621.1555
Jean_Intel
Hello blfuentes,
Thank you for posting on the Intel️® communities. We would be more than glad to help you with the problem you described.
For this, it is important to mention that there are two different types of drivers, generics provided by Intel and Equipment Manufacturer drivers, that are customized to work with each specific system. Drivers from the system manufacturer may have different versioning concerning the Intel Generic Driver. The best thing to do is to use the drivers provided by the system manufacturer (OEM) or through Windows Update to eliminate the potential impact caused by loading non-custom drivers.
Jean O.
Jean_Intel
Hello blfuentes,
Jean O.
blfuentes
Thanks for the clarification. I just rolled back to the windows update version and let the myasus driver manager update whatever he needed to.
Jean_Intel
Hello blfuentes
Thanks for your response.
Since you marked this thread as solved We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
MHA
I am using HP Laptop 450 G8 Probook. the display driver is Intel Iris Xe G. i am looking for a stable display driver version for windows 11pro 25H2. The current available version of display driver 32.0.101.7077. this is flickering my screen. can you share me the stable driver link
