23851 Discussions
Intel hd graphics hd 505 - Driver problems
BWing1
I wanted to update my intel hd graphics driver but after i tried to update them i got the message that my computer does not meet the system requirements [ talking about drivers 15.60 ]. Tried to contact your live chat support - BUT ITS INNACTIVE. PLS JUST FIX YOUR DRIVERS BECAUSE I'M DONE WITH YOU AND WITH YOUR WORK. 2 CORE PENTIUM PROCCESOR OR 1 CORE CELERON FROM THE STONE AGE WORKS BETTER THAN THIS PENTIUM M4200 IN GAMES AND IN EVRYTHING ELSE. SYSTEM - INTEL PENTIUM N4200, AMD RADEON R5 M430, 8GB RAM DDR3.
Stefan3D
Try drivers from this list https://downloadcenter.intel.com/product/96552/Intel-HD-Graphics-505 Downloads for Intel® HD Graphics 505
Since you have switchable graphics you can force applications to run on AMD GPU if you suspect Intel graphics ain't working.
Check out:
community.amd.com/docs/DOC-1581
support.hp.com/us-en/document/c03048374
BWing1
Tried with all the drivers there and it's the same, i switched to the AMD GPU a long time ago but the client does not care and runs most of it on CPU and i suspect the intel pentium n series because this is my second laptop with n series procesor ( i use n3540 before ) and its the same.
