22727 Discussions
Intel i5 10400F with Intel Arc A750
Sukanta
I have intel i5 10400f and currently using gt710 GPU. Just thinking to buy intel arc A750. Just want to know should I and will there be any bottleneck as I want to use it mostly for video editing.
Thank you
MUC
Honored Contributor I
MUC
This depends primarily on your motherboard:
What Is Resizable BAR and How Do I Enable It?
Sukanta
The motherboard is Gigabyte B410m S2 V2
MUC
There is nothing wrong with using an Intel Arc A750 on this platform. Please update the BIOS to latest version F5 and set the following:
  • Advanced Mode → Settings → Above 4G Decoding → Enabled
  • Advanced Mode → Settings → Re-Size BAR Support → Auto
  • Advanced Mode → Boot → CSM Support → Disabled
  • Advanced Mode → Save & Exit
Sukanta
Thanks a lot. Just one more thing, I currently have Corsair 500W PSU. But when I check recommended psu for Intel Arc A750 it’s 550w min. Do I must need to my upgrade my PSU to 550 or above or I’ll be quite ok with my 500w psu???
Pc Spec:
i5 10400F
MB Gigabyte B410M S2 V2
16 GB Ram
240 GB m.2
1TB HDD
*GPU will be Intel Arc A750
Thank you
MUC
The processor is specified with 65 W Thermal Design Power (TDP). The 10th generation Comet Lake processors go up to 125 W depending on the model. If your other devices connected to the computer are not power guzzlers either, then I think it is almost impossible that you will get problems with the existing 500 W power supply.
