23854 Discussions
Intel virtualization
Alefrian
Eu ativei a função Intel virtualization para jogar bluestacks e quando fui jogar outro jogo percebi que minha cpu está usando mais que a gpu qual o problema?
Senkuchan
Valued Contributor II
Senkuchan
Can you provide the specific model of your processor? You can find out how to check it by following this link: https://www.intel.com/content/www/us/en/support/articles/000006059/processors.html#:~:text=Windows*&text=on%20your%20keyboard%20and%20start,and%20speed%20of%20the%20processor.
For more information about the virtualization, you can refer to this link: https://www.intel.com/content/www/us/en/support/articles/000005486/processors.html
Alefrian
Eu tenho i3 9100 e uma rtx 2060 de 6gb e fui ativar quando eu voltei percebi que a cpu está usando mais que a gpu ficou assim depois que ativei Intel virtualização
Senkuchan
Have you updated the drivers of your computer? That might be the reason for the issue. Also, share the ssu logs of your computer with me, so that I can verify your system configuration. You can find the link here:
Additionally, what troubleshooting steps you have tried and when did the issue begin?
Alefrian
ocorreu esse problema dia 24/01 e atualizei a bios da placa mãe, desisntalei e instalei os drives da placa de vídeo
Alefrian
Está com a placa gráfica que eu removi a placa de vídeo
Senkuchan
refer to this website for more guidance on how to fix this issue:
https://www.intel.com/content/www/us/en/support/articles/000091441/graphics.html#:~:text=Clean%20Install%20the%20graphics%20driver,background%20while%20using%20the%20application.
I have also looked at some forums in bluestacks, where they share some advice on how to improve your settings. Here are some of the websites I found:
https://www.bluestacks.com/blog/bluestacks-exclusives/best-settings-for-low-end-pcs-en.html/amp
https://support.bluestacks.com/hc/en-us/articles/360057389932-How-to-change-the-graphics-settings-on-BlueStacks-5
You can also explore other forums from bluestacks for more information.
