22789 Discussions
Intermittent Low GPU Power Usage and FPS Drops After Restart – Intel Arc A750
memento999
I am experiencing an issue with my Intel Arc A750 GPU. After restarting my PC, I occasionally notice low GPU power usage and significantly reduced FPS while gaming. The problem persists until I restart the PC a couple more times, after which the GPU starts performing normally again.
Here are some key details:
  • The issue happens after a restart, but sometimes the GPU performance is restored after restarting multiple times.
  • I have updated to the latest Intel Arc GPU drivers.
  • Power settings are set to “High Performance” in Windows.
  • I have monitored the GPU temperature, and it seems to be within normal ranges.
  • I have tried disabling Fast Startup in Windows, but the issue still occurs.
  • My motherboard BIOS is up to date, and I have Resizable BAR enabled.
Could this be a driver-related problem, or might there be a conflict with power management settings? Any guidance or troubleshooting steps to resolve this issue would be greatly appreciated.
Thank you for your assistance!
Mike_Intel
Hello memento999,
  1. When did you purchase this unit?
  2. Was it working fine before?
  3. Did you change any settings before the issue started?
  4. Are you using an Intel brand Arc A750?
  5. Can you share the specification of your power supply?
  6. Can you also share the troubleshooting steps that you tried so far specially if you already tried different hardware components?
Michael L.
Mike_Intel
Hello memento999,
Michael L.
Mike_Intel
Hello memento999,
I am sending another follow up on the information that I requested.
Michael L.
