22968 Discussions
Iris Xe Graphics Not Support Game Old MMORPG
itsnull12
Hi Team,
I have ASUS Vivobook using Iris Xe Graphics. My problem is, i cant playing game old like RF Online. Stuck and force close after 3-5 minute, maybe not support rendering. Please solution.
Jean_Intel
Hello itsnull12,
Thank you for posting on the Intel️® communities. We understand that you are having issues when playing RF Online.
We would like to further investigate the issues you are reporting. Provide me with the following:
  • What are the games distribution service? ( Blizzard, Epic, Origin, Steam, Xbox, Ubisoft connect).
  • Is the issue present since day one?
  • Have you tried using different driver versions?
  • Do you receive an error message when the game closes?
  • Share a video showing the issues you are experiencing.
  • Create a system report using the Intel®️ System Support Utility (Intel®️ SSU)
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
Jean O.
itsnull12
    CCR, LYTO
    Yes
    Yes, still crash and force close
    No have error message
Jean_Intel
Hello itsnull12,
Thanks for the information provided,
Perform a clean driver installation for the latest ASUS graphics driver, 30.0.101.1660. Sometimes corrupted files from previous installations of drivers can linger on a system which can cause driver updates to not work as expected. It is important to mention that there are two different types of drivers, generics provided by Intel and Equipment Manufacturer drivers, that are customized to work with each specific system. The best thing to do is to use the drivers provided by the system manufacturer (OEM).
Jean O.
Jean_Intel
Hello itsnull12,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello itsnull12,
Best regards.
Jean O.
Balmart
Hello Jean_Intel
I experienced exactly the same thing with itsnull12. I've tried almost everything like:
  • update graphic driver with the newest and clean installation.
  • change the resolution in the game.
  • install the old direcX
The game still freeze like itsnull12 give you the video. What should I do?
Best Regards
Balmart
