23095 Discussions
Is MCH Voltage important for RAID stability?
I have 6 disks (1500GB) and have two raid array. Raid 0 and raid 5. I checked all of the disks for read/write speed and bad sectors, there is no problem. But when i am copying files between raid 0 and raid 5 vloumes, IMSM reported that the one of the disk has i/o error. then i marked it as normal and rebuild poreccess started. when the procces finished i start to copy files but same problem occurs with different harddisk.
should i change the mch voltage because of the 6 sata hdd's?
