23538 Discussions
Is The Intel Arc A750 Compatable With My Motherboard?
roddurgamerz
I want to know if Intel Arc A750 is compatible with Gigabyte B760M Gaming C DDR4.
roddurgamerz
My bad Its Gigabyte B760M Gaming X DDR4
Jean_Intel
Hello roddurgamerz,
Thank you for posting on the Intel️® communities. We understand that you are looking for information about the compatibility between your motherboard and the Intel® Arc™ A750.
Regarding your questions, your motherboard seems to meet the Intel® Arc™ A-Series Graphics System Requirements. It is important to mention that the Motherboard requirements are the following:
  • Full-size PCI Express 3.0 (or newer) x16 slot
  • Resizable (Re-Size) BAR
Based on your motherboard specifications, it has a 1 x PCI Express x16 slot, supporting PCIe 4.0, meeting the first requirement.
Note that System BIOS configuration can have a significant impact. System BIOS is designed to support configurations for a broad range of devices, and some default configurations may not be optimal for Intel® Arc™ A-Series Desktop Graphics. You should contact GIGABYTE support to confirm if your motherboard has Resizable (Re-Size) BAR and if their BIOS configuration supports Intel® Arc™ graphics.
Jean O.
Jean_Intel
Hello roddurgamerz,
We hope you are doing fine.
Best regards.
Jean O.
