22712 讨论
Is it possible to use headless Chrome on Linux with --use-gl=egl
fludge
初学者
4,371 次查看
Card: Intel Arc A770/16GB
I've spent days trying to configure Linux to run headless Chrome with the --use-gl=egl command line option.
I do not know at this stage if it is because this is simnply an impossible goal, or if I do not have it configured right in some way.
Can anyone confirm if this is possible or impossible?  If impossible then I can give up.
Here is the command:
DISPLAY=:0 /opt/google/chrome-unstable/chrome --headless --use-gl=egl --run-all-compositor-stages-before-draw --remote-debugging-address=0.0.0.0 --remote-debugging-port=9222 --window-size=1920,1080 --ignore-gpu-blocklist
Here is the result:
DevTools listening on ws://0.0.0.0:9222/devtools/browser/d25accdc-c76b-4116-bb67-7572f9e88ace
[0329/205920.979482:WARNING:bluez_dbus_manager.cc(247)] Floss manager not present, cannot set Floss enable/disable.
[0329/205921.010645:FATAL:gpu_init.cc(497)] Passthrough is not supported, GL is egl, ANGLE is
[0329/205921.071170:ERROR:gpu_process_host.cc(953)] GPU process exited unexpectedly: exit_code=133
[0329/205921.071189:WARNING:gpu_process_host.cc(1303)] The GPU process has crashed 1 time(s)
[0329/205922.015328:FATAL:gpu_init.cc(497)] Passthrough is not supported, GL is egl, ANGLE is
[0329/205922.078777:ERROR:gpu_process_host.cc(953)] GPU process exited unexpectedly: exit_code=133
[0329/205922.078790:WARNING:gpu_process_host.cc(1303)] The GPU process has crashed 2 time(s)
[0329/205923.395388:FATAL:gpu_init.cc(497)] Passthrough is not supported, GL is egl, ANGLE is
[0329/205923.457826:ERROR:gpu_process_host.cc(953)] GPU process exited unexpectedly: exit_code=133
[0329/205923.457842:WARNING:gpu_process_host.cc(1303)] The GPU process has crashed 3 time(s)
[0329/205924.288818:WARNING:sandbox_linux.cc(393)] InitializeSandbox() called with multiple threads in process gpu-process.
[0329/205924.290225:WARNING:gpu_process_host.cc(976)] Reinitialized the GPU process after a crash. The reported initialization time was 830 ms
0 项奖励
2 回复数
Jean_Intel
员工
4,343 次查看
 Hello fludge,
Thank you for posting on the Intel️® communities. We understand that you are looking to use headless Chrome on Linux.
Based on your issue, the best course of action is to contact the software developer and your Linux distribution support for further recommendations about this matter.
Jean O.
0 项奖励
Jean_Intel
员工
4,274 次查看
Hello fludge,
We hope you are doing fine.
Best regards.
Jean O.
0 项奖励
回复
