22927 Discussions
Is my motherboard compatible with a Intel Arc 750?
timms
is a dell motherboard 048dy8 compatible with an Intel Arc A750?
Im new to pc building and trying to use what i already got.
AlHill
You will need to ask dell regarding compatibility with their board.
Jean_Intel
Hello timms,
Thank you for posting on the Intel️® communities. We would be more than glad to help you.
We would like to add that the motherboard requirements, as stated in here, for the Intel® Arc™ A-Series Graphics are the following:
  • Full-size PCI Express 3.0 (or newer) x16 slot
  • Resizable (Re-Size) BAR
 However, as previously mentioned, you should contact your motherboard manufacturer to confirm the compatibility with your board.
Best regards
Jean O.
Jean_Intel
Hello timms,
We hope you are doing fine.
Best regards.
Jean O.
