23092 Discussions
Is there a hotkey / 1-click method to change resolution or select a Profile?
MM_D
I want the quickest way to change my laptop's resolution (or the resolution on my extended desktop when I have an external monitor connected.)
But with the Intel Graphics shell command, I have to:
1. Right-click
2. Select Graphics Options dropdown
3. Select Profiles dropdown
4. Select my preferred profile (or if i don't have a Profile saved, steps 3 & 4 would be Graphics Options...Resolution...Built-in Display...select resolution)
Not ALL that hard, but should be an easier way. I see the Intel Graphics menu has HOTKEYS, but i don't think it's possible to configure a hotkey to change resolution / or select a profile.
Anyone have a super-quick method to share?
Hello darknite55:
In regard to your question, those will be the steps needed in order to change the resolution of the laptop, for this option there is not a hotkey that allows you to change or set up the resolution besides those steps.
Alberto
Hello darknite55:
I just wanted to check if the information posted previously was useful for you and if there is something else that we can assist you with?
Alberto
JPACA
Hi
or can i Export graphics profile to File MyGraphicsProfile ?
and then double click on "MyGraphicsProfile"....would change the profile
It is so possible ?
Hi, PACALA_BA, Yes, you can do that, on the link below you will find additional details about the Intel® graphics profile:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005857.html%23ExportImport http://www.intel.com/content/www/us/en/support/graphics-drivers/000005857.html# ExportImport
Alberto R
