22733 Discussions
Graphic driver crash creating a D3D11_SM4 pixel shader with recent hlsl compiler
JLUCE1
I've recently updated our hlsl compiler with Windows kit 8.1's fxc.exe.
But some (very simple) pixel shader make igd10umd32.dll crash after a call to CreatePixelShader() with new byte code.the
Here is the byte code of the shader (given to CreatePixelShader)
char ByteCodes[] = {
0x44, 0x58, 0x42, 0x43, 0xDF, 0x86, 0xAB, 0x1E, 0x92, 0x1F, 0x5F, 0x21, 0x96, 0x0B, 0x38, 0xD0, 0x9C, 0xEE, 0xB6, 0x64, 0x01, 0x00, 0x00, 0x00, 0xFC, 0x02, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00,
0x34, 0x00, 0x00, 0x00, 0xB4, 0x00, 0x00, 0x00, 0xE8, 0x00, 0x00, 0x00, 0x1C, 0x01, 0x00, 0x00, 0x80, 0x02, 0x00, 0x00, 0x52, 0x44, 0x45, 0x46, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x04, 0xFF, 0xFF, 0x00, 0x01, 0x00, 0x00, 0x46, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00,
0x05, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x54, 0x4D, 0x61, 0x70, 0x49, 0x6E, 0x70, 0x75,
0x74, 0x00, 0x4D, 0x69, 0x63, 0x72, 0x6F, 0x73, 0x6F, 0x66, 0x74, 0x20, 0x28, 0x52, 0x29, 0x20, 0x48, 0x4C, 0x53, 0x4C, 0x20, 0x53, 0x68, 0x61, 0x64, 0x65, 0x72, 0x20, 0x43, 0x6F, 0x6D, 0x70,
0x69, 0x6C, 0x65, 0x72, 0x20, 0x36, 0x2E, 0x33, 0x2E, 0x39, 0x36, 0x30, 0x30, 0x2E, 0x31, 0x36, 0x33, 0x38, 0x34, 0x00, 0x49, 0x53, 0x47, 0x4E, 0x2C, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00,
0x08, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x03, 0x00, 0x00, 0x53, 0x56, 0x5F, 0x50,
0x6F, 0x73, 0x69, 0x74, 0x69, 0x6F, 0x6E, 0x00, 0x4F, 0x53, 0x47, 0x4E, 0x2C, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x01, 0x0E, 0x00, 0x00, 0x53, 0x56, 0x5F, 0x44, 0x65, 0x70, 0x74, 0x68, 0x00, 0xAB, 0xAB, 0xAB, 0x53, 0x48, 0x44, 0x52,
0x5C, 0x01, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00, 0x58, 0x18, 0x00, 0x04, 0x00, 0x70, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x55, 0x55, 0x00, 0x00, 0x64, 0x20, 0x00, 0x04,
0x32, 0x10, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x65, 0x00, 0x00, 0x02, 0x01, 0xC0, 0x00, 0x00, 0x68, 0x00, 0x00, 0x02, 0x03, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x05,
0x32, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x46, 0x10, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x29, 0x00, 0x00, 0x07, 0x32, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x46, 0x00, 0x10, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x36, 0x00, 0x00, 0x08, 0xC2, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2D, 0x00, 0x00, 0x08, 0xF2, 0x00, 0x10, 0x00, 0x01, 0x00, 0x00, 0x00, 0x46, 0x0F, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00,
0x46, 0x7E, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2D, 0x00, 0x00, 0x88, 0x01, 0x02, 0x00, 0x00, 0xF2, 0x00, 0x10, 0x00, 0x02, 0x00, 0x00, 0x00, 0x46, 0x0F, 0x10, 0x00,
0x00, 0x00, 0x00, 0x00, 0x46, 0x7E, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x07, 0x12, 0x00, 0x10, 0x00, 0x01, 0x00, 0x00, 0x00, 0x0A, 0x00, 0x10, 0x00, 0x01, 0x00, 0x00, 0x00,
0x0A, 0x00, 0x10, 0x00, 0x02, 0x00, 0x00, 0x00, 0x2D, 0x00, 0x00, 0x88, 0x01, 0x20, 0x00, 0x00, 0xF2, 0x00, 0x10, 0x00, 0x02, 0x00, 0x00, 0x00, 0x46, 0x0F, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00,
0x46, 0x7E, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2D, 0x00, 0x00, 0x88, 0x01, 0x22, 0x00, 0x00, 0xF2, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x46, 0x0E, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00,
0x46, 0x7E, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x07, 0x12, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x00, 0x10, 0x00,
0x02, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x06, 0x01, 0xC0, 0x00, 0x00, 0x0A, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x00, 0x10, 0x00, 0x01, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x01,
0x53, 0x54, 0x41, 0x54, 0x74, 0x00, 0x00, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
I've joined the minidump debugger says:
"Unhandled exception at 0x66C03309 (igd10umd32.dll) in GbxGame.exe.1700.dmp: RangeChecks instrumentation code detected an out of range array access."
Here are the system spec.:
Intel HD Graphics 3000
Video BIOS: 2119.0
Driver Version: 9.17.10.4459
OS: Windows 10 Pro (10.0.14393)
Could you tell me what is going on please ?
(going back to previous hlsl compiler version is not trivial for us)
AlHill
Intel HD 3000 Graphics are not supported on Windows 10:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
The best you can do on Windows 10 is to get the driver from here: http://www.catalog.update.microsoft.com/Search.aspx?q=intel%20hd%203000%20graphics%20windows%2010 Microsoft Update Catalog
Doc
JLUCE1
Thanks for fast feedback, you're right but,
I've a player with a
[Sys] Gpu Adapter 0: (0x8086,0x0166) "Intel(R) HD Graphics 4000", 2 Outputs, 32MB dedicated video, 0MB dedicated system, 1 760MB shared system
[Sys] Os = Windows 8.1(9600.winblue_ltsb.170204-0600) 64bhis
I don't know his driver version but I can ask him.
But to get back to my question, I'm almost sure his crash is the same than this one.
And about windows 10 + 3000, I've the latest from the link you gave.
JLUCE1
I've a solution:
On all Intel graphics, I'll skip the 2 shaders which makes that driver crash.
(they're not mandatory: zbuffer downsize)
I could do better by checking also the driver version.
Before with D3D9 it was easy (it was part of adaptater description).
But now with D3D11 I don't know how to get that driver version.
Do you know a robust way of getting that ?
Thank you very much to Al Hill for providing the information above.
Hi, JSeb, Thank you very much for joining the Intel® Graphics communities.
As it was mentioned before, the Intel® HD Graphics 3000 graphics controller is not supported on Windows® 10, based on that some errors are expected.
Now, if you need to get more details about this matter, in that case you can always visit our developer zone to get further peer assistance:
https://software.intel.com/en-us/forum https://software.intel.com/en-us/forum
Any further questions, please let me know.
Alberto
JLUCE1
Hello Alberto and Al Hill again,
Hum few points, just to be clear:
a) I understand my test configuration is not "ideal": I'm using an HD 3000 on windows 10 which is not officially supported.
I fully understand that point.
b) But one of our players as an issue (driver crash on same shader code) very close to the one I reproduce on my (a) test configuration.
And this player is using an HD 4000 on Windows 8, I don't have it's driver version yet, but I assume he've the latest.
c) I found a solution in our case to avoid these driver crash.
So this issue is no longer "so important to me".
d) I'm quite surprised you keep talking me about point (a) rather than asking yourself if that issue could also concern "officially supported systems".
Best regards
Stefan3D
JSeb schrieb:
I've a solution:
You might get further support in the developer forum: https://software.intel.com/en-us/forums/developing-games-and-graphics-on-intel Developing Games & Graphics on Intel
Probably you should post your shader as source code there, byte code is impossible to read (at least for me).
Stefan3D, Thank you very much for your suggestion.
Alberto
Hi, JSeb, I hope the information posted previously was useful for you and that you were able to get further assistance on the Intel® developer zone.
Let me apologize for any inconvenience.
Alberto
