23531 Discussions
Is there an Intel G41 Express Chipset driver update that supports OpenGL on Windows 8.1 x64?
RPire
Hello guys,
I have been always using a software of astronomy called Stellarium on Windows 7 x64, without any problem. But now, I installed it on Windows 8.1 x64 and when I try to open it, an error message says: "Your platform does not support the minimum Open GL 1.2 required. Please, update the drivers of your video card."
As we can see, that's not a hardware problem because I have already used Stellarium in the same pc, but there's a problem with the driver of my graphics. My video card is the Intel G41 Express Chipset and there's no update driver of this video card, for Window 8/8.1 in the Intel Download Center. Is this a configuration problem in my system?
I am an amateur astronomer and this is my favourite planetarium simulator, so any help is gonna be very apreciated.
Thanks in advance.
@renatronic
OS: Windows 8.1 Pro x64
CPU: Intel® Core™2 Duo CPU E7500 @ 2.93GHz
Mainboard: ASUS P5G41T-M LX V2
Graphics: Intel G41 Express Chipset
RAM Memory: PATRIOT DDR3 4Gb (3965Mb available physical memory)
Drive Info:
C: Sata 465,42 Gb (system root)
F: Sata 1863,01Gb
Power Supply: SANTECH 500 Watts — PSU 500/ATXndows
Allan_J_Intel1
Hi renatronic,
The G41 Express driver is provided by Microsoft within your Windows 8.1 (32-bit, 64-bit) installation. This type of driver is called Inbox, and this is a native driver that is supplied with the Operating System.
In other words, the driver is automatically installed during installation. If you are looking for an updated driver, they are available through Microsoft Windows Updates.
See the following URL for additional information:
http://www.intel.com/support/graphics/sb/CS-033838.htm http://www.intel.com/support/graphics/sb/CS-033838.htm
Allan.
Miw
Finally got it working
Allan_J_Intel1
I am glad to hear that you were able to resolve your issue. Your feedback is important to us and I thank you for taking the time to communicate this issue.
Allan.
CMahe1
Umm A Problem I Cant Run Open Gl Games/Programs.
CMahe1
I Get This.
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:252)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at bsu.am(SourceFile:523)
at bsu.aj(SourceFile:352)
at bsu.a(SourceFile:299)
at net.minecraft.client.main.Main.main(SourceFile:120)
CMahe1
Solved: https://www.youtube.com/watch?v=52inEl2eXrs Minecraft Windows 7, 8, 8.1 Fix Mobile Intel® 4 Series Express Chipset Family - YouTube
Allan_J_Intel1
I am glad you have fixed this problem.
Allan.
