23486 Discussions
Is there an "Iris Plus Graphics 655" with only 47 EUs?
H-Takeda
Hi, I'm mainly enjoying running AI on NUC8i3BEH !
But then one day I realized.
Fewer GPU execution units (EU) are recognized in the App.
The SoC of NUC8i3BEH is i3-8109U.
The internal GPU of the i3-8109U is "Iris Plus Graphics 655".
Many documents found on Intel show the "Iris Plus Graphics 655" as being 48EU.
For example, the API of C for Metal displays 1 EU less.
(The Iris Plus Graphics 655 has 7 hardware threads in 1EU.
Thus, if there are 48 EUs, it should be "HW thread count : 336".)
GT3
HW thread count: 329
GPU min frequency: 0 MHz
GPU max frequency: 0 MHz
Threads per group: 49
Is this a software problem?
However, several people have said that the Iris Plus Graphics 655 is 47EU.
https://en.wikichip.org/wiki/intel/core_i3/i3-8109u
https://www.tomshw.it/hardware/intel-prepara-bean-canyon-nuc-con-gpu-iris-plus-graphics
The above problem also appears on the i3-9100.
(The i3-9100 shows it as 23EU).
If you have a model that reduces the EU by one, why is that?
Sebastian_M_Intel
Hello H-Takeda,
Thank you for posting on the Intel® communities.
Please let us review this inquiry internally, once we have an update we will share it through this thread.
Kindly wait for a response.
Sebastian M
Intel Customer Support Technician
H-Takeda
Have you made any progress since then?
I'm curious.
Sebastian_M_Intel
Hello H-Takeda,
Thank you for waiting.
After checking, this seems to be a software issue. Is there a way that you can test with a different reporting application? Perhabs CPU-Z or similar?
Additionally, please provide the following reports:
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
  • Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
  • Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2.DxDiag report:
  • In Windows, select Start and enter dxdiag into the search box on the taskbar. Select dxdiag from the results.
  • In the tool, select Save All Information for an easily shared format.
Sebastian M
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
Sebastian_M_Intel
Hello H-Takeda,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M
Sebastian_M_Intel
Hello H-Takeda,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Sebastian M
H-Takeda
Sorry....
It seems that the reply was late.
Questions are now closed, but I'm just going to report.
My PC's OS is Linux (Ubuntu).
I did not know how to use DxDiag in Linux.
I don't know of any other software that can display the EU as well as the above question.
SSU had a Linux version.
. /ssu.sh -o=All_Information.txt
The output text of this command is attached.
It may not be convincing, but that's all the information I can give you right now.
Translated with www.DeepL.com/Translator (free version)
