23489 Discussions
how can i share ram to gpu
haert
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
haert
AlHill
Your graphics will allocate up to 50% of available system memory.  You need not do anything.  If you want more memory available for graphics, just add more memory to your system.
If you are talking about dedicated memory, that is the past and you should forget about it.
https://www.intel.com/content/www/us/en/support/articles/000020962/graphics.html
haert
haert
my lasttime i use laptop is 3 years ago i juat lowtec with this thankyou
