23748 Discussions
lag during gaming
deveshjs
While playing Valorant , the game freezes frequently and the GPU (INTEL UHD 630) usage drops to 1% and the power usage is very high. Due to this I am not able to play the game.
I hope this problem can be solved.
Sebastian_M_Intel
Hello deveshjs,
Thank you for posting on the Intel® communities.
So we can have more information from your system, please provide the following:
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
  • Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
  • Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2. Provide the Report for Intel® Graphics Drivers, follow this link
3. Was this game playable before? If yes, do you remember making any changes before the issue started?
Sebastian M
Intel Customer Support Technician
Sebastian_M_Intel
Hello deveshjs,
I can see that you have another thread about the same behavior with more details here: https://community.intel.com/t5/Graphics/lag-during-gaming/m-p/1230476#M91744
In order to avoid duplication of efforts, we will close this inquiry and the support will continue via the thread mentioned above.
Sebastian M
