23069 Discussions
Kabylake HD630 no display on Panasonic LED TV
cchia10
My setup is:
i3 7100 on Asus B250M-A mobo (HTPC, windows 10 64bit, with latest BIOS 0809)
via HDMI connect to
Yamaha RX-V677 AV Receiver
via HDMI connect to
Panasonic TH-60A430K LED TV
I had been using the above setup for months without problem, until recently when Intel released new driver version with version number starting from 22.xx.xx
The last working version is 21.20.16.4678, and all other version before this was also working correctly.
it was since last month, first Microsoft update center installed the version 22.xx.xx, ever since them every new version will give me problem, the symptom is that the TV will give total blank and no display. there will be display during start up (BIOS loading screen), Windows loading screen, and it goes blank immediately after the driver is loaded and i cannot see the windows log in screen. i can still login the HTPC using teamviewer, so i can confirm that windows is loaded up correctly and not hang.
i can revert the driver back to 21.20.16.4678 using teamviewer and it will solve the problem.
i tried bypass the yamaha receiver but still same result. so we can say it is not related to receiver.
i dont think this is the Panasonic compatibility issues, because all previous driver from intel or microsoft is working fine.
kindly advise me a solution. thank you.
cchia10
I cant find how to upload attachment......
so i paste here the current/last known working driver version here, any newer driver version after this one is not working for me.
Intel(R) HD Graphics 630
Report Date: Saturday, August 5, 2017
Report Time [hh:mm:ss]: 3:48:16 PM
Driver Version: 21.20.16.4678
Operating System: Windows* 10 Pro (10.0.16251)
Physical Memory: 6209 MB
Vendor ID: 8086
Device ID: 5912
Device Revision: 04
Video BIOS: 1050.0
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz
Processor Speed: 3912 MHz
Processor Graphics in Use: Intel(R) HD Graphics 630
Shader Version: 5.1
OpenGL* Version: 4.4
OpenCL* Version: 2.1
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 12.0
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Television *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 50.39 inches
Vertical Size: 28.35 inches
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
720 x 480 (60i Hz)
720 x 576 (50i Hz)
720 x 576 (50p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1280 x 720 (50p Hz)
1280 x 720 (60p Hz)
1280 x 1024 (60p Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (60p Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (24p Hz)
1920 x 1080 (25p Hz)
1920 x 1080 (30p Hz)
1920 x 1080 (50i Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 34 A9 96 A2 01 01 01 01
00 18 01 03 80 80 48 78 0A DA FF A3 58 4A A2 29
17 49 4B 21 08 00 31 40 45 40 61 40 81 80 01 01
01 01 01 01 01 01 02 3A 80 D0 72 38 2D 40 10 2C
45 80 BA 88 21 00 00 1E 02 3A 80 18 71 38 2D 40
58 2C 45 00 BA 88 21 00 00 1E 00 00 00 FC 00 50
61 6E 61 73 6F 6E 69 63 2D 54 56 0A 00 00 00 FD
00 17 3D 0F 44 0F 00 0A 20 20 20 20 20 20 01 5A
02 03 3B F5 4D 9F 90 14 05 20 21 22 13 04 12 03
16 07 38 09 7F 07 0F 7F 07 15 07 50 3E 1F C0 4D
02 00 57 06 00 67 7E 00 5F 54 01 68 03 0C 00 11
00 B8 26 0F E2 00 4B 83 5F 00 00 01 1D 80 D0 72
1C 16 20 10 2C 25 80 BA 88 21 00 00 9E 01 1D 80
18 71 1C 16 20 58 2C 25 00 BA 88 21 00 00 9E 01
1D 00 BC 52 D0 1E 20 B8 28 55 40 BA 88 21 00 00
1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 75
* Other names and brands are the property of their respective owners.
cchia10
# SSU Scan Information
Scan Info:
Version:"2.5.0.8"
Date:"08-05-2017"
Time:"00:00:27.7187409"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"ASUSTeK COMPUTER INC."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends Inc. 0809 , 10-07-2017 12:00 AM"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz , GenuineIntel"
Secure Boot State:"Not Available"
SMBIOS Version:"3.0"
Sound Card:"Realtek High Definition Audio"
Sound Card:"Intel(R) Display Audio"
Sound Card:"USB Audio Device"
System Manufacturer:"System manufacturer"
System Model:"System Product Name"
System SKU:"SKU"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"21.20.16.4678"
- "Intel(R) HD Graphics 630"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) HD Graphics 630"
Link:" http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+630"
CoInstallers:"oem116.inf,iKBLD_w10_DS,Internal,Intel(R) HD Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"05-17-2017 08:00 AM"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\igdlh64.inf_amd64_6d1fd205efa7f979\igdkmd64.sys"
Driver Provider:"Intel Corporation"
INF:"oem116.inf"
INF Section:"iKBLD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"igdumdim64,igd10iumd64,igd10iumd64,igd12umd64,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_5912&SUBSYS_86941043&REV_04\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"24 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"23 Hz"
Resolution:"1920 X 1080"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) HD Graphics Family"
- "Memory"
Physical Memory (Available):"3.76 GB"
Physical Memory (Installed):"8 GB"
Physical Memory (Total):"6.06 GB"
- "BANK 0"
Capacity:"4 GB"
Channel:"ChannelA-DIMM1"
Configured Clock Speed:"2133 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First position"
Manufacturer:"Apacer"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"78.B1GM3.AU00B"
Serial Number:"71316525"
Status:"Not Available"
Type:"Not Available"
- "BANK 2"
Capacity:"4 GB"
Channel:"ChannelB-DIMM1"
Form Factor:"DIMM"
Interleave Position:"Second position"
- "Motherboard"
BIOS:"BIOS Date: 07/10/17 12:53:24 Ver: 05.0000C, ALASKA - 1072009"
Caption:"Motherboard"
- "Chipset":"Intel(R) 200 Series"
Link:"<a class="jive-link-external-small" href="https://communities.intel.comhttp://www.intel.com/content%...
Stefan3D
it was since last month, first Microsoft update center installed the version 22.xx.xx, ever since them every new version will give me problem...
If you suspect major version 22.x to be broken try 21.20.16.4727 from Microsoft:
http://download.windowsupdate.com/c/msdownload/update/driver/drvs/2017/07/02522adf-40c6-4cbf-a579-ea0b73b8c6e1_10f5d5d2c3e01f306753ec9186f4d20950c937ad.cab http://download.windowsupdate.com/c/msdownload/update/driver/drvs/2017/07/02522adf-40c6-4cbf-a579-ea0b73b8c6e1_10f5d5d2c
Create a system restore point
https://support.microsoft.com/en-us/instantanswers/e6bbddb0-9db4-4d88-9063-42c52c79a96e/create-a-system-restore-point
Install the driver via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
Treat CAB like ZIP
cchia10
Thank you, i installed 21.20.16.4727 from Microsoft and it is working correctly.
so obviously something was different after 22.x which make it incompatible to my LED TV.
hope intel will find out solution from the next release.
