23837 Discussions
Kindly Help!!
SAhuj
I am using Intel core2 duo e7400 2.80 GHz and there are no graphic drivers available for this product.
AlHill
There are no graphic drivers for the http://ark.intel.com/products/36500/Intel-Core2-Duo-Processor-E7400-3M-Cache-2_80-GHz-1066-MHz-FSB Intel® Core™2 Duo Processor E7400 (3M Cache, 2.80 GHz, 1066 MHz FSB) Specifications because it does not have graphics.
Provide more information about your system (model, manufacturer, GRAPHICS, Operating System, etc.
Doc
SAhuj
AlHill
Ok, still need more. What graphics device, what system model number and/or motherboard do you have?
Doc
SAhuj
Intel(R) Processor Identification Utility
Version: 5.50.20160527
Time Stamp: 2016/07/24 14:26:18
Operating System: 6.1-7601-Service Pack 1
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 2
Disabled cores per processor: 0
Processor Name: Intel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz
Type: 0
Family: 6
Model: 17
Stepping: A
Revision: A07
Maximum CPUID Level: D
L1 Instruction Cache: 2 x 32 KB
L1 Data Cache: 2 x 32 KB
L2 Cache: 3 MB
Packaging: LGA775
Enhanced Intel SpeedStep(R) Technology: Yes
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: Yes
Intel(R) AES-NI: No
Intel(R) AVX: No
Enhanced Halt State: Yes
Execute Disable Bit: Yes
Intel(R) Hyper-Threading Technology: No
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: Yes
Intel(R) VT-x with Extended Page Tables: No
System Graphics: Add-in Graphics
Expected Processor Frequency: 2.80 GHz
Reported Processor Frequency: 2.09 GHz
Expected System Bus Frequency: 1066 MHz
Reported System Bus Frequency: 797 MHz
AlHill
Ok, one more time. RUN the DXDIAG tool. On the DISPLAY tab, look under DEVICE, NAME and tell me what graphics you have.
Doc
SAhuj
name:Standard VGA graphics Adapter
manufacturer:Standard display types
chip type:Intel(r)915G/915GV/910GL graphics chip
AlHill
Ok, your graphics are http://www.intel.com/content/www/us/en/support/graphics-drivers/graphics-drivers-for-intel-82915g-82910gl-express-chipset-family.html Intel® 82915G/82910GL Express Chipset Family. This chipset is not supported on Windows Vista, 7, 8.x, and Windows 10.
Look way down this page under "legacy": http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
Doc
SAhuj
Can u exactly tell me what should i do now or send me the exact links of drivers.
Hi Sahil_Ahuja,
Sadly, your system is very old now and there are only drivers available for Windows XP. They were released on 2007.
Downloads for Graphics Drivers for Intel® 82915G/82910GL Express Chipset Family
https://downloadcenter.intel.com/product/81527/Graphics-Drivers-for-Intel-82915G-82910GL-Express-Chipset-Family https://downloadcenter.intel.com/product/81527/Graphics-Drivers-for-Intel-82915G-82910GL-Express-Chipset-Family
If you want an earlier operating system, I suggest you to install it and run Windows update, maybe the Microsoft generic driver will work.
Mike C
SAhuj
can u clear it in Team Viewer.
Hi Sahil_Ahuja,
Intel support is only available for active products, your processor and chipset are out of support now. I suggest you to follow up the links that I provided to you before.
Regards,Mike C
