23257 Discussions
Kishonti GFXBench 4.0 crash
Stefan3D
Kishonti just released a new version of their cross-platform OpenGL benchmark - https://kishonti.net/news_single.jsp?id=27817230 https://kishonti.net/news_single.jsp?id=27817230
On my Optimus rig it passes all tests in a row with GeForce GPU, but not with integrated GPU.
Note: GFXBench is picky with ALT-TAB
I'm not familiar with your GPA so i tried good old IDA (demo 6.8), offsets below are after "memory re-basing" and only for the mentioned driver version.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
If you select all tests app crashes most likely between "Manhattan" and "Manhattan offscreen" test
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
Works fine with single tests
Hardware (HW)
Brand and Model of the system.
Acer E5-571G
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
NVIDIA Optimus
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP
How much memory [RAM] in the system (see note2 below).
8 GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
N/A
<td style="border: 0px solid black; padding: 0 5.4pt 0 5.4pt; bord...
Amy_C_Intel
Hello Stefan3D,
Does it crash with the following version https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]?
Amy.
Stefan3D
Yes, crashes also with driver 20.19.15 4300
I made one run with and one without IDA debugger.
2 non-crucial exceptions at launch screen:
Debugger: Library loaded: C:\Program Files (x86)\Kishonti Ltd\GFXBench GL\bin\icudt52.dll
gfxbench_gl.exe: Software breakpoint exception (0x77A3CEAC)
Debugger: Library loaded: C:\WINDOWS\SysWOW64\ig8icd32.dll
Debugger: Library loaded: C:\WINDOWS\SysWOW64\wtsapi32.dll
gfxbench_gl.exe: 0x7710D8A8: unknown exception code E06D7363 (0x7710D8A8)
This time crash at "1080p Manhattan offscreen" loading screen:
Debugger: Library loaded: C:\Program Files (x86)\Kishonti Ltd\GFXBench GL\plugins\gfxbench40_gl.dll
gfxbench_gl.exe: The instruction at 0x5F70688F referenced memory at 0xC4430BD3. The memory could not be written (0x5F70688F -> C4430BD3)
Amy_C_Intel
Thank for that information.
Let me run some tests on this matter, I will be updating this thread.
Amy.
Amy_C_Intel
Stefan3D, could you please fill out the following form and post it here, I know you already added some of that information but in order to escalate this we need all the information requested on the link, so please make sure to follow closely all the instructions.
Regards.
Stefan3D
I added disp diag dump to first post.
SSU 1.0.1.5 fails to run in spite of executing as admin.
If you have an older or newer version i'll retry.
gbhj
Amy_Intel this error also happens with the iris 5100 when the 1080p car chase is being loaded
i have included my SSU report
Stefan3D
Changelog of driver 20.19.15.4326 claims to have fixed the crash, but not for me.
It's now down to one exception though.
I made 3 runs with these results:
Manhattan
gfxbench_gl.exe: The instruction at 0x55920C61 referenced memory at 0x4. The memory could not be written (0x55920C61 -> 00000004)
Manhattan
gfxbench_gl.exe: The instruction at 0x557C541F referenced memory at 0xB3444BD3. The memory could not be written (0x557C541F -> B3444BD3)
Manhattan 1080p offscreen
gfxbench_gl.exe: The instruction at 0x5FC9541F referenced memory at 0xBDF42BD3. The memory could not be written (0x5FC9541F -> BDF42BD3)
Amy_C_Intel
Hello zeqzy,
Thank you for adding your SSU report, could you please fill out the following form /thread/77761 Default level information for reporting Graphics issues and post it here, make sure to follow closely all the instructions in order to proceed with an escalation.
Stefan3D, thank you for including that information.
Amy.
Amy_C_Intel
Hello all,
There is a new driver version available that should fix this issue, note the picture below;
Please give it a try;
https://downloadcenter.intel.com/download/25541/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
Release Notes;
https://downloadmirror.intel.com/25541/eng/ReleaseNotes_GFX_15%2040%204326_Final.pdf https://downloadmirror.intel.com/25541/eng/ReleaseNotes_GFX_15%2040%204326_Final.pdf
Let me know your findings.
Regards.
Stefan3D
Yet another try with driver 20.19.15.4331 WHQL, issue persists.
One run without debugger, two runs with IDA:
gfxbench_gl.exe: The instruction at 0x5C114C2F referenced memory at 0xB3252BD3. The memory could not be written (0x5C114C2F -> B3252BD3)
Manhattan
gfxbench_gl.exe: The instruction at 0x578D4963 referenced memory at 0x10. The memory could not be read (0x578D4963 -> 00000010)
Amy_C_Intel
This driver version 20.19.15.4331 does not seem to be on our official download center site. Any issues with that particular driver version I am afraid are not going to be address.
Regards.
Stefan3D
@ Amy_Intel
GFXBench passes now all tests with driver 20.19.15.4377 + Windows 10 build 14257 on my rig.
