Some times when I power on my computer I have a few screen resolutions options to choose from. But most of times not.
What is wrong with my computer?
I tried updating my Intel Graphics Driver to the latest version, still the probem remains.
I don't want/need a too fancy screen resoultion, but I want to use something like 1280x800
DRIVERS DETAILS (from Intel auto-detect service)
GRAPHICS INFORMATIONGraphics Product [1]http://www.intel.com/p/en_US/support/highlights/gr Intel®HDGraphics2500orIntel®HDGraphicsGraphics Driver Version 10.18.10.42763D AccelerationYesHardware Transform & Lighting Support YesVideo Memory1.5 GBVertex Shader Support 5.0Pixel Shader Support 5.0Microsoft DirectX* Version 11.0Link Copied
Hello rafaelvidal,
I would like to recommend you to please complete a manual install, for the latest driver available with the Intel® HD Graphics 2500:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html inhttp://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Windows® 10 and Windows 8*/8.1*
https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81501 Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33] (Version: 15.33.43.4425 (Latest) Date: 5/13/2016)
If the issue persists, please reply with the following information:
-Which will be the model of your laptop or desktop board?
-If it is a laptop, which will be the model of the monitor? and which type of cable or connection are you using?
-Which Operating System are you using?
-Which processor do you have?
Hope I can hear from you soon.
Angie.
Motherboard: MSI
Model: MS-7788
Desktop
Windows 7 32bit
Intel(R) Pentium(R) CPU G2020 @ 2.90GHz, 2900 Mhz
Hello rafaelvidal,
Thanks for the information provided.
I would like to confirm 2 more details:
Which graphic driver do your have?
And, have you installed the driver that I have provided to you?
I am looking forward to hearing from you.
Angie
rafaelvidal,
I am following up your thread, and I wanted to check if you need further assistance on this matter. If yes, please provide the information requested in post # 3 in order to proceed.
Amy.
yes, I did installed the one driver you provided.
No, it didn't work.
Hello rafaelvidal,
For testing porpuses, could you please install the following drivers and let me know if the issue persists with any of them.
https://downloadcenter.intel.com/download/25698/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81501 Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33]
Version: 15.33.42.4358 (Previously Released)
Version: 15.33.35.4176 (Previously Released)
Hello rafaelvidal,
https://downloadcenter.intel.com/download/25698/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-%3Fproduct%3D81501 Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33]
https://downloadcenter.intel.com/download/24825/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81501 Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33]
Please let me know how it goes in order to further assist you if required.
Angie
Hello rafaelvidal,
I would like to confirm a few details more, in order to continue with the investigation.
-This change on the available resolutions that you see, happens when you connect your desktop to one monitor?
-Are you connecting your desktop to the same monitor when you see the change?
-Which will be the model of the monitor?
-If the issue is related to one monitor, could you please provide me with the model?
-If you are using more than one monitor, or if you exchange the monitor when you connect your desktop, could you please provide me with both models?
Angie
1-This change on the available resolutions that you see, happens when you connect your desktop to one monitor?
It happens sporadically. It isn't predictable.
Tonight, I turned on my computer and all the resolution options were there.
By the time of this post the options are all there.
2-Are you connecting your desktop to the same monitor when you see the change?
Yes.
Always the same monitor. I never change.
3-Which will be the model of the monitor?
Samsung SyncMaster 592v
4-If the issue is related to one monitor, could you please provide me with the model?
Not applicable.
I never change the monitor.
That's not the case.
I could maybe try to connect to a different monitor to see if it enables other resolutions than 800x600 and 1024x768.
SCREEN RESOLUTIONS OPTIONS
Hello rafaelvidal,
I would like you to please try the next steps:
-First, try to connect everything with a different cable.
-Then try to connect it to a different monitor.
Angie
Hello rafaelvidal,
I would like to confirm if you were able to get any different results; or any positive results of the previous steps that were suggested.
In case if you need further assistance do not hesitate to reply back.
Angie.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
