22940 Discussions
Laptop Intel HD Graphics 4400, Flickers and black screen
SGonz21
Hello, i Have a question about my laptop Acer with intel hd graphics 4400 4th Gen. Usually my screen flicks when i use to much process and the screen of laptop turns black when i play games (in example Need For Speed Underground 2, Slender the Arribal, Battlefield) or when i use Unity for programming, but if i connect the HDMI or VGA in a second monitor works perfectly. I have the lattest drivers installed, i have a windows 10, 4 GB Ram and intel Core I3 4030u. Why my laptop do this? How i solve this? . Regards
AlHill
Bad laptop, in my opinion.
Doc
SGonz21
I suspect the same. But I still can't change it, that's why I want to try to do something to repair it (if possible)
LeonWaksman
What is the Windows version?
What is the driver version?
Leon
SGonz21
My windows is windows 10 Pro and the lattest drivers installed is 20.19.15.5063. I attach a text file with the information on my Intel HD 4400 laptop
SGonz21
I attach my dxdiag files in case it is useful
LeonWaksman
You have Windows 10 version 1909 installed. The Intel Graphics Driver version 20.19.15.5063 is not supported for gen 4th graphics in this Windows versions. The following Windows versions are supported for your CPU and this driver:
4th Generation Intel(R) Core(TM) processor family (code name Haswell)
Microsoft Windows(R) 10-64 Anniversary Update (1607)
Microsoft Windows(R) 10-64 Creators Update (1703)
Microsoft Windows(R) 10-64 Fall Creators Update (1709)
Microsoft Windows(R) 10-64 April 2018 Update (1803)
In this case, I suggest that you uninstall this driver (from Apps and Features or from Device Manager) and leave the Microsoft Basic Graphics Driver.
Leon
SGonz21
OK. I did what you recommended and now the driver version 10.18.15.42.48 was automatically installed ... I still see some flickers from time to time at this time but I will do some tests on games to see if I improve the diagnosis
LeonWaksman
1. Download from Microsoft https://support.microsoft.com/en-us/help/4026726/windows-10-hide-updates-or-driver-updates this Show Hide Tool: http://download.microsoft.com/download/F/2/2/F22D5FDB-59CD-4275-8C95-1BE17BF70B21/wushowhide.diagcab
2. Uninstall the 10.18.15.42.48 driver, leave the Microsoft Basic Graphic Driver.
3. Use the Show Hide Tool to stop the Graphics Driver automatically updating.
4. Check how the laptop works with the Microsoft Basic Graphic Driver.
Leon
SGonz21
I follow the steps and with some flickers the games run with lagging. The driver installs anyway automatically
LeonWaksman
If you will hide the Graphics Driver update, using Show Hide Tool, it will not be reinstalled automatically. You also can stop automatic update in Windows Settings > Update & Security > Advanced Options.
Leon.
SGonz21
ok i shutted down the automatic graphic driver update, now i have the windows driver basic. Games run with too much lag but the black screen is no more. can i install a driver compatible?
LeonWaksman
You have an Acer E5-471 laptop, so this question you should ask in Acer forum rather than here. The latest driver release for your laptop by Acer is 10.18.15.4248 https://global-download.acer.com/GDFiles/Driver/VGA/VGA_Intel_10.18.15.4248_W10x64_A.zip?acerid=635735802814510590&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%20E5-471&OS=ALL&LC=en&BC=ACER&SC=AAP_7 . You may try this, however I can't predict how it will work in Windows 10 1909 and if the result will be better than with the Microsoft Basic Driver.
Leon
SGonz21
