23833 Discussions
Laptop screen flickers
PunitB
Attached is the system information, please suggest the solution asap..
David_G_Intel
Hello PunitB
Thank you for posting on the Intel️® communities. Please share more information with us:
  • When did this issue start?
  • Does this same thing happen with the Microsoft Basic Display adapter (uninstalling the graphics driver)?
  • Does this happen with a specific application?
  • Do you get the same problem with a second monitor?
  • Please share a short video with us to get a better understanding of the problem.
David G
Intel Customer Support Technician
PunitB
Hi, this is a new laptop just bought couple of weeks back.
Yes i have unistalled and installed the intel graphics driver from device manager
No, it happens from browser tab to tab and with any applications as well
I have second monitor which is HD TV - it happens over the same as well
I will share the video in the next reply
PunitB
Here is a short video...flicker may not be prominent. But the brightness changes from tab to tab and from screen to screen
ClariceStarling
Valued Contributor II
If it's brand new, that sounds like a loose connection somewhere ... especially for the laptop monitor.  Fact the second monitor also does it makes it more complicated, but I'm still going to guess it's a manufacturing defect.   You might not want to keep it too long before sending it back!
PunitB
hi, thanks for the quick response. Whats the process of getting it repaired or sending back to service center?
ClariceStarling
To return under warranty you have to go to the Dell website for a Dell computer!
David_G_Intel
Thanks for the information provided by @PunitB. If the same thing happens with different manufacturer's drivers, Intel drivers, and even no driver (Microsoft Basic Display Adapter) it means that the drivers are not the problem.
In the video the problem is not very noticeable but if you want a physical evaluation of the system, check directly with the manufacturer of the laptop or with the place of purchase.
David G
