告知
23469 ディスカッション
Latest Installer crashes before installing/opening
Ben444333
初心者
8,950件の閲覧回数
So what happened, Well I went to instal latest driver version at the time being 31.0.101.4672 After downloading it, it would extract then sometimes open before crashing/closing by itself I then tried installing 31.0.101.4578 and well it installed but the Arc control would not open, I then turned off my PC and turn it back on going into the motherboard bios and turn of my IGPU which fixed it not opening how I know to turn off my IGPU I first turn it off in windows which allowed it to open but showed the wrong driver version so turning off my IGPU fixed that but it would stay I am on latest driver version which I am not and the two latest driver versions are like that too.
I have DDU "Display Driver Uninstaller" my old GPU drivers, both Intel and Nvidia
Old GPU Zotac nvidia gtx 1060
New GPU ARC A 750 8Gb
Screen one is msi mpg Artemis 273cqr curved 27inch 2k 165 Hz
Screen two is msi mag Artemis 242c curved 24inch 1080p 165 Hz
system specs are in txt file
1 解決策
Hugo_Intel
従業員
8,933件の閲覧回数
Hello Ben444333
Thank you for posting on the Intel Communities. I know is important to be able to install the latest driver to take advantage of the latest improvements I will be glad to assist.
For these types of issues where the installer is crashing after extracting we have the following troubleshooting steps that you can try:
Intel® Arc™ Graphics Driver Installer Won't Start
I would advise trying to extract the field from the installer and do a manual installation as outlined in the article, this step should allow the installation to go through.
Hugo O.
元の投稿で解決策を見る
4 返答(返信)
Hugo_Intel
従業員
8,934件の閲覧回数
Hello Ben444333
Hugo O.
Ben444333
初心者
8,929件の閲覧回数
Hugo_Intel
従業員
8,915件の閲覧回数
Hello Ben444333
Great to know that the manual installation of the driver, helped getting this issue resolved. Since this fixed the problem we will proceed to close this thread. Feel free to open a new topic in case you need assistance with any other issue.
Hugo O.
Ben444333
初心者
8,866件の閲覧回数
No any time I try and use the install it crashes, so I do it manually instead.
返信
