23772 Discussions
Latest P45 Chipset Drivers?
Hello, I am trying to update my system drivers on Windows 7 64bit but I can't find some of them. I installed many versions of the Inf Installation Utility but it doesn't update all the Intel system drivers. I am missing the following ones:
Intel(R) 82801 PCI Bridge - 244E
Intel(R) 82802 Firmware Hub Device
Also I used DriverMax to check my drivers and it stated that most of my Intel drivers are out of date.
Thanks for your help.
Hi, you can try this one:http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=10884&lang=eng
But to be honets it would help mor eif you provided more info like what motherboard/laptop it is.. Also i would suggest you reinstall the OS, then install the chipset first, then audio video lan and anything else.
I tried this version and it says that it installed successfully but it didn't update the drivers. The computer is custom made and it has the Asus P5Q Deluxe motherboard. This is what I get from the DriverMax driver report:
Driver Your verLatest ver Intel(R) ICH10 Family SMBus Controller - 3A301.0.0.29.1.1.1004http://www.drivermax.com/driver/device.php?id=PCI%2BVEN_8086%26DEV_3A30%26SUBSYS_82D41043%26REV_00%2B6.1%2B64&driver=Intel%28R%29+ICH10+Family+SMBus+Controller+-+3A30
Intel(R) 82801 PCI Bridge - 244E9.1.1.10129.1.1.1012http://www.drivermax.com/driver/device.php?id=PCI%2BVEN_8086%26DEV_244E%26SUBSYS_82D41043%26REV_90%2B6.1%2B64&driver=Intel%28R%29+82801+PCI+Bridge+-+244E
Intel(R) 4 Series Chipset Processor to I/O Controller - 2E209.1.0.10129.1.1.1012http://www.drivermax.com/driver/device.php?id=PCI%2BVEN_8086%26DEV_2E20%26SUBSYS_82D31043%26REV_03%2B6.1%2B64&driver=Intel%28R%29+4+Series+Chipset+Processor+to+I/O+Controller+-+2E20
Intel(R) 4 Series Chipset PCI Express Root Port - 2E219.1.0.10129.1.1.1012http://www.drivermax.com/driver/device.php?id=PCI%2BVEN_8086%26DEV_2E21%26SUBSYS_82D31043%26REV_03%2B6.1%2B64&driver=Intel%28R%29+4+Series+Chipset+PCI+Express+Root+Port+-+2E21
High Definition Audio Controller6.1.7600.163856.1.7600.16385http://www.drivermax.com/driver/device.php?id=PCI%2BVEN_8086%26DEV_3A3E%26SUBSYS_83111043%26REV_00%2B6.1%2B64&driver=High+Definition+Audio+Controller
Intel(R) ICH10R LPC Interface Controller - 3A169.1.0.10139.1.1.1004http://www.drivermax.com/driver/device.php?id=PCI%2BVEN_8086%26DEV_3A16%26SUBSYS_82D41043%26REV_00%2B6.1%2B64&driver=Intel%28R%29+ICH10R+LPC+Interface+Controller+-+3A16
Intel(R) ICH10 Family PCI Express Root Port 6 - 3A4A9.1.0.10139.1.1.1004http://www.drivermax.com/driver/device.php?id=PCI%2BVEN_8086%26DEV_3A4A%26SUBSYS_82D41043%26REV_00%2B6.1%2B64&driver=Intel%28R%29+ICH10+Family+PCI+Express+Root+Port+6+-+3A4A
Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40<img border="0" height="16" src="http://www.drivermax.com/ima...
Personally what i would do is reinstall the OS. As soon as you have installed it, without installing anything else install the drivers form the ASUS support page for your motherboard in this order ( this is important) chipset audio video (for oyur GPU form teh manufacturers page) LAN and any otehr driver, don't forget the ATK0110 driver for WindowsXP/Vista/Win7 32&64-bit also. Then once all done and in teh device manage you have no missing drivers nor yello bangs, let windows update go, if there are any other updated drivers they will come through windows update. and forget about drivermax, just let windows update when it gets a new driver.
Create a shortcut of the .exe setup right click to properties > and add in the target box a space after .exe -OVERALL.
INF_allOS_9.1.2.1007_PV.exe -OVERALL
Apply and run the shortcut.
Did running the setup with the -OVERALL switch work for you guys? Because I tried this and for me, the driver for the Intel(R) 82801 PCI Bridge - 244E still shows up as 'outdated' and is the 1.0.0.2 version and not the 9.x.x.x latest from Intel. Not sure how to fix this.
