23544 Discussions
Latest driver in old system
OldMan50
Backstory:
SLOWLY updating my system, started with an upgrade of a graphics card with the A750 (from a 750Ti)
MB is an Asus Z97-A  (bios rev 2015), CPU a 4th gen Intel, 32GB DDR3.
Motherboard does not appear to support Resizeable BAR ... BUT does allow the 4G decoding.
Installed A750, updated drivers to ....4255, worked nicely.
The current situation:
This morning, updated drivers to latest (4314) and an issue.
Booted into windows (10), allowed login via password and loaded in desktop. Was presented with a functioning mouse pointer but could not access programs or start menu.
Currently resolved by removing the A750 and re-installing the 750Ti.
New mb/cpu/ram not arriving till June so the system will be in its current configuration for that time, but would like to use the A750.
Would like to know how to roll the driver back to 4255 or what would my options be?
Stefan3D
Boot in safe mode
Right-click START
open device manager -> graphics card -> properties -> driver -> previous version
OldMan50
Thank you for your reply Stefan, I will go down that route when I have replaced the A750 back into the computer
Is there any way that I can proceed with rolling back the drivers WITHOUT having the associated graphics card in the machine?
Hugo_Intel
Hello OldMan50
Thank you for posting in the Intel Communities. I am sorry that you are experiencing freezing issues when installing the driver version 31.0.101.4314 on your system.
If I may jump into the conversation I would like to let you know that the GPU will need to be installed in order to roll back the driver to the previous one so the system can recognize the display adapter.
We would also like to recommend you to update and test the latest driver version 31.0.101.4335. First, uninstall the current driver using Display Driver Uninstaller. Once uninstalled, install version 31.0.101.4335.
If the issue still persists, please create a log file with the Intel® System Support Utility and attach it to your response.
Hugo O.
Hugo_Intel
Hello OldMan50
I hope you are doing fine.
Hugo O.
tawrus80
Hugo,
I had the same symptoms with the .4314 driver as OldMan50.  I tried the .4335 beta driver you suggested and, again, had it freeze (with live mouse) after install as well as reboot.  I reverted back to .4255 and all is well now.
The larger thread on this issue is here;
https://community.intel.com/t5/Graphics/arc-a750-display-freeze-after-updating-to-latest-driver/m-p/1481188
Hugo_Intel
Hello tawrus80
Thank you for posting. We are currently investigating this issue and so far seems to be related to older hardware not listed in our requirements article and that generally do not have support for Resizable Bar.
The owner of this thread has not posted for a while now and in that case, the thread will no longer be monitored. Please in order to further assist, create a new thread and post the log files from Intel® System Support Utility and Intel Graphics Command Center (Intel GCC).
Hugo O.
Hugo_Intel
Hello OldMan50
I have not heard back from you. So I will close this thread. As mentioned in my last post the issue is being investigated, however, we cannot commit to a specific outcome or estimated time for resolution since the issue is happening in older configurations. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
