22682 Discussions
the question about my inside graphic of 13500h
zz580586
my new notebook(asus adol14va),the cpu is i5-13500h,but the inside graphics is intel uhd graphics。So,is there a special 13500h that the gpu is not ires xe?  or is the drives problem?
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
AlHill
No, do not send me the report in a PM.   Attach the report to this thread.
n_scott_pearson
If your system has only a single DIMM (or two DIMMs in same channel) installed, you are going to see the iGFX run in limited mode - and be identified as UHD Graphics. With dual channel mode enabled (i.e., matched DIMMs installed in each channel), the iGFX will run unlimited - and be identified as Iris Xe Graphics.
