23854 Discussions
Latest driver?
mnaum1
Whats the latest driver for Intel Iris Plus Graphics 650 in the Intel NUC 7i7BNH running Windows 10?
Your site lists two different drivers and its a bit fuzzy on which on to use. And they are at different versions..
Stefan3D
Check the date stamps at https://downloadcenter.intel.com/product/98912/Intel-Iris-Plus-Graphics-650 Downloads for Intel® Iris™ Plus Graphics 650
Hello, nmbrg.
I would like to know if you could install the drivers with the link Stefan3D provided above.
Antony S.
mnaum1
Yes, i can install it.
Im still not sure which driver is the latest for my hardware/OS though.
The reason i ask is because the driver installed is crashing when trying to use hardware accelerated transcoding for HEVC videos with subtitles (any subtitles).
So i wanted to make sure i used the latest one.
The driver im using at the moment is:
Version: 24.20.100.6025
Date: 2018-04-25
Stefan3D
Meanwhile 24.20.100.6094 has been released
https://downloadcenter.intel.com/download/27803/Graphics-Intel-Graphics-Driver-for-Windows-10 Download Intel® Graphics Driver for Windows® 10
mnaum1
Thanks!
Though it did'nt solve my problem, atlest now i know which driver is the latest (and which to use).
Hello, everyone!
nmbrg: There is a new graphics drivers version (6136). Here is the download link: https://downloadmirror.intel.com/27847/a08/win64_24.20.100.6136.zip https://downloadmirror.intel.com/27847/a08/win64_24.20.100.6136.zip
gadencourt: If the troubleshooting steps above did not work for you, please create a new thread explaining your problem. Make sure you include your system configuration and a clear explanation about the issue so we can give you a solution as soon as possible.
Antony S.
Hello, nmbrg.
I would like to know if you could install the drivers I provided in my previous post and the results.
Antony S.
mnaum1
yes, the newest drivers are installed. but still not solving my problem.
Thank you for your reply, nmbrg.
In which software or application are you having this issue? Please specify the name and version.
Additionally, please share with me the .txt file that the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Antony S.
Hello, nmbrg.
I was wondering if you still need assistance. If so, do not hesitate to reply back to this thread.
Antony S.
pgade
I tried this driver too. It's working, but badly when using adobe premiere cc 2017. If I use the openCL option (graphic acceleration) all the colors are bad. If no acceleration, colors are good, but I do not use the GPU acceleration. Not so easy to install those NUCs. Drivers seem not to be very stable and finished.
