20815 Discussions
Lenovo M910q with i5-7500T, graphics hd630
Eagle07
Hi! I have an Mini PC Lenovo M910q with i5 7500T, with graphics card hd630. It has 2 display ports v1.2, i think is two independent channels, and i want to know if i connect 1 monitor 1440p in each DP i did not have problems at 60hz, 75hz? Second question what is the maximum i can connect in each DP. I want to work with 2 monitors at same time. Thanks
Hugo_Intel
Hello Eagle07
Thank you for posting on the Intel Communities. I understand that you are looking to know if your system can support 2 displays with a 1440p@60Hz or 75 Hz resolution. We will be glad to help.
Based on the specifications sheet(Attached) for this system, it can support up to 3 displays with a maximum resolution of 4096x2304 (DP)@60Hz, so the configuration that you are trying to achieve should be possible, however, we would recommend that you reach out to your system manufacturer support to make sure there are no limitations.
Hugo O.
Hugo_Intel
Hello Eagle07
We hope that you were able to check the previous post as well as the datasheet we share for your laptop model which indicates the configurations that you are looking for should be possible. Since there are no further questions related to this topic we will close this thread, feel free to open a new thread if you have further questions.
Hugo O.
