23257 Discussions
Lighting Problems on Intel Iris Xe and ARC series (Sonic Frontiers)
pankekesveraf
There's an issue present in both Iris Xe and Arc series GPUs where the lighting would make the game's overworld be really dark, making it hard to see.
It seems it's mostly prevalent when the game switches to the night as during the day it's seems mostly fine. In addition, all the water in the game seems to not load at all just leaving black pools.
For reference, here is a video demonstrating the issue:
https://twitter.com/WatchSilasTV/status/1590094138657378304
-Lighting and water
https://twitter.com/AsparingA/status/1591038483396964354
-Water
This problem seem to occur only on Intel GPUs at the time and no other platforms seems to run this problem.
Andres_Intel
Hello pankekesveraf,
Thank you for posting on the Intel®️ communities.
To have a better understanding please answer the questions:
  • Does this issue happen with different Intel® Graphics cards or with a specific model?
  • What troubleshooting steps have you done?
  • What game version do you have installed?
  • Download, run, save and attach the report for the following tool Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
pankekesveraf
Hi, thansk for answering.
The problem seems to occur on most Intel graphics cards like Iris Xe and Arc. It's seems like a problem on Intel cards in general
I found a solution to this problem by using DXVK 2.0 Async, a Vulkan-based translation layer for Direct3D 9/10/11 which allows running 3D applications on Linux. For reference, my OS is Windows and it fixed all issues
My version of the game is 1.01
The report that Intel® System Support Utility gave me is at the end of this comment
Hope this can help fix this issue on Itel graphic cards as most users may not know about DXVK
Andres_Intel
Thank you for the feedback provided it is really important to us.
As you have found the solution to the issue, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
