23767 Discussions
Linux: No HDMI Audio with Intel UHD Graphics 630
Major-Mayer
Hi everybody,
I have the problem that I don't get any sound from my Intel UHD Graphics 630 (Core i5-8600K) when connecting a display via HDMI.
Video is working without any problems, but the display just doesn't appear in the audio device list:
As you can see, other devices like my AMD graphics card work without any problems.
I am using Manjaro Linux on Kernel 6.6.32, so pretty up to date:
Operating System: Manjaro Linux
KDE Plasma Version: 6.0.5
KDE Frameworks Version: 6.2.0
Qt Version: 6.7.1
Kernel Version: 6.6.32-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 6 × Intel® Core™ i5-8600K CPU @ 3.60GHz
Memory: 31.2 GiB of RAM
Graphics Processor: AMD Radeon RX 6800
Manufacturer: Micro-Star International Co., Ltd.
Product Name: MS-7B46
System Version: 1.0
The kernel driver is i915
00:02.0 Display controller: Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630]
       DeviceName: Onboard - Video
       Subsystem: Micro-Star International Co., Ltd. [MSI] Device 7b46
       Kernel driver in use: i915
       Kernel modules: i91
Any help would be very appreciated.
Edit:
Maybe some logs could help for easier debugging:
sudo dmesg | grep snd
[    7.409020] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    7.409335] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    7.409705] snd_hda_intel 0000:03:00.1: enabling device (0000 -> 0002)
[    7.410071] snd_hda_intel 0000:03:00.1: Force to non-snoop mode
[    7.471660] snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[    7.539835] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[    7.539847] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    7.539849] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    7.539850] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    7.539851] snd_hda_codec_realtek hdaudioC1D0:    dig-out=0x1e/0x0
[    7.539852] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[    7.539853] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
[    7.539854] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
[    7.539855] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
[   17.735095] usbcore: registered new interface driver snd-usb-audio
So as you can see, the Intel audio device is not listed.
It's also not the cable, because when I plug it into my AMD card, the video + sound works just fine.
Major-Mayer
Hi Williams,
I appreciate your help, but actually I wanted to delete this thread, since i've found a solution myself (It was not possible, since the thread was marked as spam).
It turned out that sound via HDMI actually works, the problem was just that the profile was hidden in one of the devices, which I didn't expect ("Internes Audio Analog Stereo" or "Internal Audio Analog Stereo"):
Using this profile, the sound actually comes through.
Thank you anyway 🙂
AllStars
hello there Mayer
I noticed that the video is working fine, but the display doesn't appear in the audio device list. Other devices, such as your AMD graphics card, work without any problems. The kernel driver in use is i915, and the Intel audio device is not listed in the logs.
Given this information, it appears to be a specific issue with the Intel audio device on your system. Since the cable works fine with your AMD card, it's unlikely to be a cable issue.
To troubleshoot further, you may want to consider checking for any driver updates or compatibility issues with the Intel UHD Graphics 630 on Manjaro Linux. You can visit links below which other customer reported similar issues:
Additionally, you could try reaching out to the Manjaro community or forums for assistance, as they may have encountered similar issues and can provide more tailored advice for your setup.
Williams
Major-Mayer
Hi Williams,
Thank you anyway 🙂
