I have the following GPU running on Debian sid (I had similar issues on a laptop at work with Ubuntu and Windows 10).
00:02.0 VGA compatible controller [0300]: Intel Corporation GeminiLake [UHD Graphics 600] [8086:3185] (rev 06)
DeviceName: Onboard - Video
Subsystem: ASRock Incorporation GeminiLake [UHD Graphics 600] [1849:2212]
Kernel driver in use: i915
Kernel modules: i915
*-core
description: Motherboard
product: J4125M
vendor: ASRock
physical id: 0
serial: M80-F4007100194
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: P1.60
date: 08/13/2021
capacity: 16MiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen in
t9keyboard int14serial int17printer acpi usb biosbootspecification uefi
If I use video acceleration (checked with intel_gpu_top), the screens turn off for a second, then everything is normal egain. When the video stops playing, it turns off again.
After disabling hardware acceleration in the browser, this does not happen.
The monitors are fine. One is connected via VGA (eDP in xrandr) and the other via DVI-D (HDMI2)
m@ryz:~$ xrandr
Screen 0: minimum 320 x 200, current 2960 x 1050, maximum 16384 x 16384
eDP1 connected primary 1680x1050+1280+0 (normal left inverted right x axis y axis) 473mm x 296mm
1680x1050 59.95*+ 59.88
1400x1050 59.98
1600x900 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1368x768 59.88 59.85
1280x800 59.81 59.91
1280x720 59.86 59.74
1024x768 60.00
1024x576 59.90 59.82
960x540 59.63 59.82
800x600 60.32 56.25
864x486 59.92 59.57
640x480 59.94
720x405 59.51 58.99
640x360 59.84 59.32
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 connected 1280x1024+0+0 (normal left inverted right x axis y axis) 338mm x 271mm
1280x1024 60.02*+
1024x768 60.00
800x600 60.32
640x480 59.94
720x400 70.08
m@ryz:~$
Resolution/refresh rate doesn't change.
What might be the problem here?
kind regards
Marco
I now figured out that it only happens if a monitor is connected to HDMI or DVI. If only VGA is being used (detected as eDP1 in xrandr), the effect does not occur.
Hello mm2021,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues with the display turning off.
- Are you using any type of adapter?
- Have you tried using other cables or video outputs?
- I understand that you mentioned that you have experienced this issue with a similar laptop with Windows 10. However, could you try installing Windows 10 on this specific system, to confirm if the issue is still present?
- If you install Windows 10, please, create a report using the
- Intel®️ System Support Utility (Intel®️ SSU)
- Download the Intel SSU
- Open the application and click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
- Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click on "Next"; then "Save."
Jean O.
I don't use any adapters or converters. I have tried other calbes, but my calbes are fine. It only occurs in the situations I described.
I also tested Lubuntu 22.10 live, the same happens, so it is not a fault of my installed Debian.
I will try out windows 10 on a second hard disk.
I have now found out that it is related to audio. If I have the internal Intel audio enabled in PulseAudio, the monitors turn off. If audio is disabled, it does not occur.
I solved it, see my post in this German Usenet newsgroup:
https://groups.google.com/g/de.comp.os.unix.linux.hardware/c/ap7jWboc3_k
Short:
I set the following boot option:
snd_hda_intel.power_save_controller=0
See that documentation for details what is does:
https://docs.kernel.org/sound/designs/powersave.html
Do you think that behaviour is a hardware issue or an issue in the Linux driver?
Hello mm2021,
Thanks for the information you provided.
We understand that the issue seems related to audio; however, as we mentioned, we may need you to test if the problem persists if you install a Windows Operating System. It is ideal to mention that our drivers are developed to work in a Windows environment. Also, if the issue persists, create an SSU report; this will gather information related to your system.
Jean O.
Hello mm2021,
Thank you for your response.
As the issue is present in the Linux Operating System environment, we recommend contacting the Linux* Operating System Vendors for further recommendations.
Jean O.
