22662 Discussões
Little Falls 2 GMA950 s-video TV detection
Funcionário
1.979 Visualizações
i woul like to buy intel Little Falls 2, but i'm not sure if i can force board to detect "TV" on s-video output. Is it possible to make card send video signel to svieo even when it thinks there is no tv connected?
Can i set custom refresh rate and resolution for svideo on GMA950?
The board have 7pin svideo connector is it supplied with cable that have one end with this 7pin and other svideo and composite (cinch)?
2 Respostas
Funcionário
722 Visualizações
I have a 7-pin and a 4-pin s-video cable. The 4-pin works, the 7-pin does not. Try a 4-pin cable, it might do the trick.
Funcionário
722 Visualizações
I'm like you, I just want to use S-Video output, but not why it does not recognize the screen almost never, sometimes, if I display an image, sometimes not. I would at least be able to use video is out but I had nothing connected. Let's see if we can help.
Greetings
PD: Forgive my English but I use translator
Responder
